Help with misfire around 5500 rpm.
I have a really annoying problem with my crx B16A1 turbo.
Around 5500rpm it tends to pop and bang and hold back. I have tried loads of things like:
Gapping the plugs down.
Checked mech timing.
Checked fuelling. All looks good. around 12:0 AFR.
Ign is retarted by 1 degree per lb/boost.
It only seems to do this when i put my foot to the floor. On half throttle it does not do it.
My spec is:
B16A1 engine standard
6.5 psi of boost
1 degree retard per lb/boost
T4 turbo
external wastegate.
Greddy profec B boost controller.
RC 550cc injectors.
I cannot seem to shift this fault.
I am tuning with crome free. and using freelog to datalog.
Any help really appreciated.
My spec is:
6.5 psi of boost
T4 turbo
external wastegate.
RC 550cc injectors.
Re: Help with misfire around 5500 rpm. (dalecrx)
There is a few things to do.
1. new plugs (and a regap)
2. New dissy wires
3 New ignitor
4.new coil
5.a new dissy that will eliminate the option 3 and 4
6.Ignition timing are set wrong(bad tune)
7. wrong A/F mix
Most likely a new set of NGK plugs gapped correct will do fine.
Please fill in if anyone have more Ideas
2. New dissy wires
3 New ignitor
4.new coil
7. wrong A/F mix
Re: Help with misfire around 5500 rpm. (atec)
1. new plugs (and a regap) Been done and this improved the problem
2. New dissy wires
3 New ignitor
4.new coil
The dizzy is only 3 months old and the problem only started when i put a new engine in the crx. I put the old dizzy on the new engine.
6.Ignition timing are set wrong(bad tune) I have tried a few different tunes but still get the problem.
7. wrong A/F mix The A/F looks quite good but wondering if its because of the change over point when you switch from low cam to high cam on the vtec.
I never has these problems on my last engine.
If it is the dizzy why would you get the fault only at a certain rpm??
2. New dissy wires
3 New ignitor
4.new coil
Re: Help with misfire around 5500 rpm. (boosted k20)
sounds lean bro, you need a proper tune. 5500 is probably where you start making boost, this happened to me when i was untuned, just wanted to rip it once on a basemap, got it up to 5500 and it ran like hell.. got it tuned and its been running awesome eversince.
Re: Help with misfire around 5500 rpm. (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">sounds lean bro, you need a proper tune. 5500 is probably where you start making boost, this happened to me when i was untuned, just wanted to rip it once on a basemap, got it up to 5500 and it ran like hell.. got it tuned and its been running awesome eversince.</TD></TR></TABLE>
if he said a/f are in the 12's then its most likely not a fuel issue. even if he was running lean ~ 13-14:1 a/f the car wouldnt break up. its most likely an ignition problem. swap out a new distr. to see if it helps. also check ur plug wires
Re: Help with misfire around 5500 rpm. (vtec.dc2)
The tune is quite good. I have spent a while working on it and it is in the 11.5 to 12 on boost.
The distributor is only 3 months old. It was brand new with cap and rotor.
will do.
I have a spare that i rebuilt a while back so hopefully it is fine.
Ill check it out in the next day or 2.
ill let you know how i get on.
shut off the boost controller and see if it does it, I tuned a car 6 months ago acme back complaining his car was bucking , backfire. Take for a ride with computer hooked up every thing was good, turned off the boost controller no problems.
DEMNTD1
07-20-2005 08:25 AM
shermanyang
08-06-2004 10:28 AM
