Good widebands
Old Mar 22, 2007 | 05:33 PM
96vtecI4's Avatar
Default Good widebands
I'm looking for a good wideband, please post up links, hoping for something cheaper(under $200) any help will be greatly appriciated!
Old Mar 22, 2007 | 06:07 PM
vtec.dc2's Avatar
Default Re: Good widebands (96vtecI4)
under 200 dollars and new? good luck.. more like 250. heres a nice one:
http://www.plxdevices.com/products_SMAFR.htm
has a nice digital 52mm display, has some extra features like simulates narroband output to your ecu so you don't need to use factory sensor.
aem also has one http://www.aempower.com/ViewPr...ID=73
do'nt know if it simulates narroband output or not but it comes with 52mm display like plx
ngk also make one. you can do a search on any of them to get more info
plx has 200 series that might be much cheaper and closer to 200 dollars, dont konw much about its features and if its still for sale new
Old Mar 22, 2007 | 06:10 PM
96vtecI4's Avatar
are EGT's and widebands similar?
Old Mar 22, 2007 | 06:15 PM
vtec.dc2's Avatar
Default Re: (96vtecI4)
wideband measures air to fuel ratio and to me is more important than EGT. EGT is exhaust gas temperature and can be used for reference if you get the readins during tuning and use later on.
most hondas come w/ narroband that measures accurate within 14.7 range, anything under or above is in the cloud. narroband output would still be usefull if you want to know if you're running really lean or in closed loop or below 14.7. wideband would tell you the exact a/f ratio, not needed but useful to have just like any other gauge
TurboEK9Coupe's Avatar
I work at Forged Performance in Georgia and we use the Innovate LM1 wide band and have really good luck with it. It sells for 375 on our web site. We use this wide band in everyone of our cars that we work on.
Old Mar 22, 2007 | 06:20 PM
96vtecI4's Avatar
So a wideband is far better then a EGT for tuning purposes? New to the whole tuning thing, and my tuner requested i get one so.
Old Mar 22, 2007 | 06:37 PM
JSPECSIR's Avatar
http://www.plxdevices.com FTMFW hit up user "streetrays" on here he has cheaper prices than plx's website.
Old Mar 22, 2007 | 07:01 PM
SFWD 1934's Avatar
Default Re: (JSPECSIR)
PLX all the way. Just go with the M300, they are about $300 shipped. Extra sensors are about $80.
Jason
Old Mar 22, 2007 | 07:08 PM
SOHCD16y8's Avatar
Default Re: (SFWD 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 &raquo;</TD></TR><TR><TD CLASS="quote">PLX all the way. Just go with the M300, they are about $300 shipped. Extra sensors are about $80.
Jason</TD></TR></TABLE>
If you search around you can find them for like 50. I got one of amazon for around there. It is a Bosch primary from a VW 1.8t.
Old Mar 22, 2007 | 07:19 PM
le0ftw's Avatar
KOBE IS GOD
Default Re: (SOHCD16y8)
if you don't want a digital display plx and innovate both have some good displays.
Old Mar 22, 2007 | 07:22 PM
vaporboy12's Avatar
Default Re: (Leo`)
I use fjo's with a ntk sensor but that way over the $300
Old Mar 22, 2007 | 10:58 PM
96vtecI4's Avatar
how do the SM-AFR's read anything? have to plug something into the box? Sorry i'm new to the whole wideband thing.
Old Mar 22, 2007 | 11:56 PM
MatrixGSR's Avatar
I had an R-500 and sold it because I didn't need the datalogger... Used it to tune a friends turbo Eclipse. I loved it. Right now I have the AEM UEGO because I got it for $215. If you're not in a hurry wait and see if you can't find something on eBay or the marketplace. GL.
Old Mar 23, 2007 | 05:53 AM
sp00led's Avatar
Default Re:
I got a PLX M-300 with bosch sensor from a sponcer on this site. No complaints and PLX had good documentation for install. The bosch sensors are pretty good to and if you have to replaced one due to running leaded fuel longterm you can replace the sensor for about $70.
Old Mar 23, 2007 | 07:01 AM
HiProfile's Avatar
You can get some widebands for that price, but with no display. A wideband will only show afr's if you aren't the tuner, so you need to monitor it to make sure it never goes rich/lean.
BTW theres also about 500 other wideband threads, if you took time to search.
Old Mar 23, 2007 | 12:15 PM
vtec.dc2's Avatar
sm afr is a controller that reads O2 sensor ouput and sends signal out to diplay and couple other outputs
you'll need dm5 display and they offer them together in a kit. dm5 will display wideband readings
Old Mar 23, 2007 | 03:45 PM
sctuned.com's Avatar
Banned
Default Re: (vtec.dc2)
Since its on topic, anybody try out those new autometer ones? We just got an email with info on them. I think its new.
AEM/PLX at the moment are the top two.
xxdevilzeroxx
Engine Management and Tuning
Oct 15, 2009 11:34 AM
CRX 2.0V-T
Dec 7, 2006 12:48 AM
hi-Powered
Sep 16, 2004 07:29 PM
_Shadow_
Dec 21, 2001 06:01 AM
