What size injectors do i need?
Old Mar 21, 2007 | 04:35 PM
zexpoweredem2's Avatar
Default What size injectors do i need?
What size injectors do i need on a 2003 honda civic coupe 5 speed d17.
I looked at the dezod turbo kit and they say i can use rsx- type s injectors as long as i don't go over 5 psi and at top rpm the injectors may start to lean out starving the motor from gas. I was woundering what would be the best size injectors to use. I heard that people use dsm injectors on some civic's will they work on mine?
They does someone make the conectors to change over from the civic's to the dsm's injector clips. Thanks for your help i hope that i
Old Mar 21, 2007 | 05:37 PM
96vtecI4's Avatar
you just get a set of dsm 450's and buy clips and resistor box from either an OBDI honda or eclipse/talon/ect. Then splice them in place of your stock clips.
01_ITR
Apr 8, 2009 03:29 AM
ShayMK
Jan 20, 2009 03:12 PM
rippinitup01
Mar 1, 2007 04:49 PM
Change
Sep 25, 2004 08:24 PM
