Help w/SOHC Turbo Setup?
Old Mar 21, 2007 | 08:46 AM
Overlook's Avatar
Default Help w/SOHC Turbo Setup?
Anyways, I was wondering if you guys could comment on my build, and add your input to everything. I'm missing a few prices, so if you happen to know them, please let me know. My goal was to hit safely 300whp, but DD it at lower boost. Please any advice would really help. Thanks alot!
Turbo D16Z6 Build
Need:
D16Z6: $800
Turbo: $GT28RS 1100
Ramhorn Turbo Manifold: $550
Downpipe: $200
Dumptube: $105
Front Mount Intercooler: $210
Oil Feed and Oil Return Lines: $???
Charge piping: $110
IC Piping - $110
Greddy Type RS Blow Off Valve: $225
2.5” Couplers/Clamps: $50
NGK BKR7E Spark Plugs: $25
Kit from TurboD16
Eagle Rods: $375 Honda 1.6, All D16 SOHC VTEC and non-VTEC and ZC 5/16" ARP 2000 Bolts- 1.771 crank pin / .748 piston pin / .898 b.e. width-NON VTECNotes: Stock
Vintara Pistons: $150
Zex Camshafts: $275
Valves & valve springs: $???
Exhaust: $???
Have:
450cc DSM injectors???
Upgraded fuel pump
Old Mar 21, 2007 | 10:35 AM
EJ1 wilcox's Avatar
Default Re: Help w/SOHC Turbo Setup? (Overlook)
Let's see here...
Looks like a good setup so far, just a few questions.
- Where did you get your pricing from? $105 for a dumptube is about 4 times what I've paid in the past.
- Charge piping and intercooler piping are the same thing, and will probably cost you more than $110.
- The couplers and clamps will cost you more than $50 unless you buy really cheap quality stuff.
- $25 for a set of plugs? Where are you buying your parts? lol
- I wouldn't worry about the cam shaft, you can easily hit 300 without even touching the head. I would save your money and leave the head stock for now.
- Go with a kteller 3" exhaust
That's all I can think of right now.
Good luck.
Old Mar 21, 2007 | 11:34 AM
KyleVA's Avatar
If you want. Message me on AIM at xKyleVAx and I'll help you work out your setup.
Old Mar 21, 2007 | 02:12 PM
Overlook's Avatar
Ok, So I was reworking the build, a few updates. I like to estimate kinda high, most the prices are close though..
Need:
D16Z6: $800
Turbo: $GT28RS 1100
Downpipe: $200
Dumptube: $105
Oil Feed and Oil Return Lines: $100
Charge piping: $110
2.5" Couplers/Clamps: $50
Kit from TurboD16
Zex Camshafts: $275
Exhaust: $ KTeller 3" Exhaust - $500
Precision 680cc injectors: $325
Hondata S300 - $700
Have:
Upgraded fuel pump
Old Mar 21, 2007 | 02:33 PM
EJ1 wilcox's Avatar
Default Re: (Overlook)
If I were you, I would plan like you have, and then just start buying parts. I've built a number of turbo systems and it doesn't always end up like I had originally planned.
I usually start with buying the turbo and or manifold combo, then go from there. Looks like you have already done a good amount of research, now the hard part is saving up for all those parts. lol
My first turbo system took me almost a year of saving, buying parts, and researching... but when it all went together like I had planned I was happy that I had done my homework. And that first time I hit boost.... oh boy. One of the best feelings ever, knowing I had built the system myself and that it worked so well.
Anyways, good luck.
Old Mar 21, 2007 | 04:37 PM
G2turbo_terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overlook &raquo;</TD></TR><TR><TD CLASS="quote">Oil Feed and Oil Return Lines: $100
Just a heads up, Stealthmode oil lines are on sale for 75, I'm sure that includes shipping too.
Old Mar 21, 2007 | 07:23 PM
dohcdelsol's Avatar
Default Re: (G2turbo_terror)
supertech valves and springs are like 600. pm the sponcer on H-T and he'll let you know a good price.
i went with ferrea for my z6 head as i plan to revvin to 9k and it cost about a 1000 for valves, valvesprings, ti retainers, and keepers. (6000 series)
and spark plugs are like 6 bucks at my napa. 25 is over kill hahaha
from what i've read, the gt28rs should easliy put you in the 300 range but i'd be suprised to see more then 350 without a port job on the head. im still a noob when it comes to understanding turbos and what they produce and teh ar and compresser wheel size still. but keep reading, ur on the right track.
Old Mar 21, 2007 | 08:36 PM
nihad's Avatar
i can get some oil line at my v8 shop they mostly sell v8 stuff but the lines are cheap *** hell like 10-15 dollars 3-4 feet long.
Old Mar 22, 2007 | 06:47 AM
Overlook's Avatar
Need:
D16Z6: $800
Turbo: $GT28RS 1100
Downpipe: $200
Dumptube: $105
Charge piping: $110
2.5" Couplers/Clamps: $100
NGK BKR7E Spark Plugs: $10
Zex Camshafts: $275
Valves & valve springs: $700
Hondata S300 - $700
Have:
Upgraded fuel pump
Total: 6,535
Still probably need a few misc parts along the way, I'm trying to cut costs though, I wasn't hoping to spend this much. I still have to buy the car, which is 2,000. Any chance their is a cheaper turbo that will put me in the same power range? Thanks alot for all the help/support guys.
Old Mar 22, 2007 | 07:18 AM
Overlook's Avatar
Sorry about the double post, but I'm just trying to figure out the setup I want done, and trying to figure out my budget.
Does anyone run a EVO III Big 16G Mitsu turbo? Here's my question, in my other thread about my build, I went all out and replaced everything. I'm getting my brothers car for 2,000, and it's all set up to run a mitsu 14B turbo. I want more power out the car, so I made a build list with prices. It got very pricey and I'm not so sure I want to spend almost 9K after everything. So here's my question, if I build up a D16Z6, swap out the 14B with a 16G, how do you think this will do? With the 14B, the engine is stock and he runs 10psi. After I build, I could swap out the 14B for the 16G because it's a direct swap, so the car would already be set up for it, and turn up the boost. This is probably cheaper, but not anywhere near as good as my original planned build. I could reuse mostly all his parts because the 14B and the 16G have the same setup. Thanks for the help.
Need:
D16Z6: $800
Turbo: EVO III Big 16G $700
Zex Camshaft: $275
Hondata S300 - $700
Have:
Upgraded fuel pump
Total: $4,125
Total w/price of car: $6,125
Much cheaper then my original build, of a total with $6,535 with just parts, and $8,535 after I bought the car. Plus if I needed help, labor costs. I'm just not sure what kind of power this would produce. I was hoping of a safe 300whp, but not run it with those settings while DD, just weekend fun and that kind of stuff. Please let me know what you guys think.
88sleeperx
Aug 21, 2006 08:33 AM
hondaddiction808
May 28, 2004 05:17 PM
Enig
Nov 16, 2003 03:07 AM
Timmayeg
Feb 15, 2003 08:39 AM
RyanAutry
Jan 6, 2003 06:53 PM
