D15b vtec plugs?
Old Mar 21, 2007 | 10:47 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default D15b vtec plugs?
I don't know **** about plugs or what the numbers even stand for. All I know is that the D15b vtec uses NGK ZFR6J-11 plugs. What the hell should I switch to for boost?
description from sparkplugs.com:
14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, ISO length, projected extended tip, V-power (v-grooved center electrode), .044"gap
Old Mar 22, 2007 | 07:39 AM
ILcrxsi1's Avatar
Default Re: D15b vtec plugs? (ILcrxsi1)
BUMP?
Old Mar 22, 2007 | 12:26 PM
jdmsiR20's Avatar
SEARCH?
https://honda-tech.com/zerothread?id=510127
https://honda-tech.com/zerothread?id=1866370
im using denso's, but the NGK part # is in there. alot of folks use the BKR7E
Old Mar 22, 2007 | 01:19 PM
ILcrxsi1's Avatar
Default Re: D15b vtec plugs? (jdmsiR20)
I searched and read those threads, but the d15b uses an oddball plug to begin with. I didn't think that that plug would be universal for almost all turbo honda's. Like I said I don't really know anything about heat ranges and numbering etc.
Old Mar 22, 2007 | 02:00 PM
jdmsiR20's Avatar
d15b vtec plugs will be the same as the d16z6.
pick up those BKR7E's and you should be golden
Old Mar 22, 2007 | 02:04 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">d15b vtec plugs will be the same as the d16z6.
pick up those BKR7E's and you should be golden </TD></TR></TABLE>No actually they're different. The z6 uses NGK# ZFR5J-11 while the d15b vtec uses ZFR6J-11. There is a 1 number difference and I don't know what it means. I think it's the heat range, which is why I didn't assume it would use the same turbo plugs.
Old Mar 22, 2007 | 04:17 PM
PrecisionH23a's Avatar
NGK 3330's
Old Mar 22, 2007 | 06:06 PM
TorganFM.'s Avatar
Default Re: D15b vtec plugs? (PrecisionH23a)
Dude... the plugs are the same except for the heat range. Higher numbers mean colder plugs. Get the BKR7E's. They will fit and are decent for turbo. Get them, and test fit them. They're $2 a pop, and you can still take them back.
Exempt
Jul 26, 2005 06:17 PM
Slipknt777
Oct 4, 2004 04:16 PM
hondaeg8
May 4, 2004 03:28 PM
1990hondaHF
Nov 11, 2003 09:54 AM
DsMWookie
Sep 19, 2002 04:34 PM
