problem with std mani and t3 turbo
Old Mar 20, 2007 | 10:46 AM
slo88hatch's Avatar
Default problem with std mani and t3 turbo
got a std mani, adapter plate, and t3 from a volvo. i tried to mount it and the wastegate hits the block. is there another way i can mount it to make it work?
Old Mar 20, 2007 | 12:25 PM
Snafubmx234's Avatar
Default Re: problem with std mani and t3 turbo (slo88hatch)
Yes.
Old Mar 20, 2007 | 04:53 PM
BEYAAAH's Avatar
Some pictures might help your cause....
Or a little more explanation
Old Mar 20, 2007 | 04:55 PM
89 crix si's Avatar
Default Re: (96EJ8eX)
its my buddies car, i havent seen it on the car, but he says that when he tries to mount it that the wastegate hits the block pretty bad. i dont even think that trimming the webbing would work. i mean, is there a way that he could make a new bracket for the wastegate or something? ill try to get some pics of it if i can. thanks for the replies guys
Old Mar 20, 2007 | 05:38 PM
welfarepc's Avatar
Default Re: (89 crix si)
clock it. u can unbolt the **** and bolt it on at 180deg. boom.
Dan
Old Mar 20, 2007 | 10:25 PM
da_dude's Avatar
I believe he is having the t3 turbo facing the driver side? If that is the case then switch the turbo so the inlet of the turbo will face the passenger side.
Old Mar 22, 2007 | 10:41 AM
slo88hatch's Avatar
Default Re: (turb20_vtec)
cant do that because the hot side of the turbo hits the dip stick
Old Mar 22, 2007 | 01:04 PM
Got_soy's Avatar
Default Re: (slo88hatch)
you have to use a smaller actuator or remote mount in to the block. i think you can also play with the bracket and get it to fit.
Old Mar 22, 2007 | 01:53 PM
HiProfile's Avatar
With a flat adapter plate, the compressor has to be on the drivers side. I think what the OP means is the wastegate <U>actuator</U> is hitting. If you look at an STR-4 turbo, the wastegate actuator's shaft has 2 bends in it. You'll have to try the same thing - moving the actuator bulb in front/above the compressor housing, and bend a 1/8-1/4" thick rod to make it work. It'd be much easier if you had a tap & die set to make threads, but you can get cheap sets for under $30.
Otherwise you can go the way the real ghetto HMT warriors go - with a chain. I've actually been toying around with the idea of a cable to relocate my actuators, since they already have very short shafts and won't fit where I want them.
If you know a good welder and buy another t3 flange, you can make this:
http://img337.imageshack.us/my...d.jpg
45 degree 2" sch40 elbow
Modified by HiProfile at 5:43 PM 3/22/2007
96teggylsse
Jul 6, 2012 12:36 PM
area522010
Feb 6, 2011 01:55 PM
96cxt
Mar 29, 2006 04:06 PM
96cxt
Welding / Fabrication
13
Mar 27, 2006 09:56 AM
MugenFlaredCRX
Oct 20, 2005 10:46 AM
