how to supply coolant to turbo? where to tap in for it?
Does anyone know or have any suggestions on where to run the coolant lines for a turbocharger? I just can't see where to get a feed and return off the motor. I could use the IACV lines,but im still running that,so how would that work? thanks in advance for any help
Re: how to supply coolant to turbo? where to tap in for it? (jsnm)
I believe my mechanic ran the water from teh obd1 b18c1 blocks factory water supply for the stock oil cooler. We then welded a return fitting into the pwr radiator.
Re: (jsnm)
Tap your smaller 3/8" line that runs to your IM with a t. One to run to the turbo and one to run back. Problem solved. Check Fast-Turbo.com I know Stan supplies these kits, I've got 4 of them
10 minutes to install.
bambam
04-13-2005 02:21 PM
