H22 Turbo Setup questions
I have a 92 prelude that I'm planing building an engine for. I am looking for 400whp wouldent mind going a little over but hopefully not under. I'm not sure what the best setup would be, so here is what I'm thinking feel free to tear it apart. Just explain why and add suggestions.
What i have:
H22A4 bottom (block, crank, etc) from a 97base.
H22A4 head from a 01sh
H23 tranny
Aem underdrive pulleys
Aem fuelrail
Str 70mm TB
Skunk 2 H22 camgears
What I'm planning (nothing is set in stone):
ERL sleeves
Crower Rods
cp pistions 9.0:1
GT35R Turbo
Turbo manifold (so many good ones hard to choose)
walpro 255hp fuel pump
1000cc injectors
Crowler Dual springs and titanium retainers
Stock h22 Valves
Head studs
Hondata s300
Please feel free to add suggestions or coments just as long as its productive.
This is not going to be a daily driver but I would like to keep it
dependable.
Edit: List Updated
Modified by dch23vtec at 4:30 PM 3/19/2007
What i have:
H23 tranny
Aem fuelrail
Str 70mm TB
ERL sleeves
Crower Rods
cp pistions 9.0:1
GT35R Turbo
1000cc injectors
Stock h22 Valves
Head studs
Hondata s300
dependable.
Edit: List Updated
Looks like a good build, but you deffinatley won't need cams for 400hp, I wouldn't use a blockgaurd, a walbro 255hp instead of the Aeromotive, and If you only want 400 I would deffiantley go with a smaller turbine because 35r's and sc61's are mid 600hp turbos and you wouldn't be taking full advantage of it.
Re: H22 Turbo Setup questions (dch23vtec)
This is just like my setup going in soon, and yea use a smaller turbo, im only using a 35r because im looking to get 500-600whp.Use CP pistons rather than JE or Weisco, they come with way better rings and are alot better quality, but of course you will be paying for it as well.
Re: H22 Turbo Setup questions (spOolin97)
what turbo would you guys sugesst? I dont want to go too big and have trouble spooling it up but i would like a little room to play if i decide I want to go for a little more later on down the line. Just take into mind I want thouse horses at the wheels. I was looking at the walpro too, thanks. taking cams off the list would help the budget. I dont make much, but would eat ramen noodles every day to buy parts for my car. Great info so far thanks guys keep it coming . What do you guys think about oversized valves, think i can make it with stock sizes?
I would think that a GT30r would be a good choice for your setup, and it would still have room for higher hp. And in all honesty, unless your head is in bad shape, I would just stick with the stock head with an upgraded valvetrain, because I have seen many high hp h22's using the stock head, and I personally wish I would have not spent all of the money I did on headwork, because it is alot of money that could be used elsewhere in the system.
Re: (BB6-213)
GT35r's are an awesome selection for a H22. i think anything smaller is too small IMO.
ive made 350-375 on 100% stock H22's on pump gas on spring pressure several times.
Re: (BB6-213)
The head is in good shape except for the bent valves in cylinder 2 caused by the broken rod in my h23vtec engine. so I have to at least change thouse valves if not upgrade them all. and why wouldent you use the blockgaurd? the a4 has floating piston walls woulden't it be safer? Thanks for the help
Modified by dch23vtec at 6:12 PM 3/18/2007
Re: (dch23vtec)
keep the 35 def 1 of tghe best turbos for a stock or mild h22 you can keep the head stock through some valves springs and retainers if you have a bent valve now pump as at about 15 psi u could easily reach your goals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dch23vtec »</TD></TR><TR><TD CLASS="quote">I have a 92 prelude that I'm planing building an engine for. I am looking for 400whp wouldent mind going a little over but hopefully not under. I'm not sure what the best setup would be, so here is what I'm thinking feel free to tear it apart. Just explain why and add suggestions.
What i have:
H22A4 bottom (block, crank, etc) from a 97base.GOOD
H22A4 head from a 01sh GOOD
H23 tranny OK
Aem underdrive pulleys REALLY DONT NEED
Aem fuelrailGOOD
Str 70mm TBGOOD
Skunk 2 H22 camgears REALLY DONT NEED
ERL sleeves (<U>possibly</U> with overbore say 2mm or so) GOOD STAY AS CLOSE TO STOCK BORE AS POS.
Blockgaurd DONT NEED
knife edged crank DONT NEED
Crower Rods GOOD
wiseco or je pistions 9.0:1 GOOD
GT35R or sc61 Turbo GOOD 35R MY PREF
Turbo manifold (so many good ones hard to choose) TRUE I USE A KOOKS MANI
Aeromotive fuel pump GOOD
injectors JUST GO FOR THE 1000CC BUY ONCE IM SURE YOU WILL NEED THEM LATER
Head port and polish DONT NEED FOR YOUR HP GOALS
Crowler Dual springs and titanium retainers GOOD
Crowler or Supertech Valves(not sure if i want to go oversize on the valves) GOOD EITHER WILL GET YOUR H/P GOALS
Crowler Turbo Cams DONT NEED
Head studs GOOD
Hondata s300 I HAVE NO HANDS ON WITH THIS
Please feel free to add suggestions or coments just as long as its productive. LOOK INTO A SET OF D.S.S AXELS NA D POS GEAR SPEED CARBON SYNCROS DEPENDING ON THE SHAPE OF YOUR TRANNY THE STOCK H SERIES TRANIES ARE FINIKY IN STOCK FORM
Edit: And this is not going to be a daily driver but I would like to keep it dependable.</TD></TR></TABLE> EAISLY A STREET SET UP
What i have:
H23 tranny OK
Aem fuelrailGOOD
Str 70mm TBGOOD
Crower Rods GOOD
Head studs GOOD
Re: H22 Turbo Setup questions (h22 civic)
some really good advice guys thanks. definitly helps my pocket knowing what i dont need. I'll probibly just get the bent valves replaced with stock ones and put the crower springs and retainers on them.
what hp are the stock valves good up to? Say if i wanted to go for mid 600's later on. Would i need the valves then or the block gaurd for the open deck?
Banned
Re: H22 Turbo Setup questions (sctuned)
This is about the same setup I will be doing on my 98 base lude. Im still debating
over the gt35 and the gt30. I want a nice street setup, not strip. I will hit the strip
now and then, but it will be my daily driver and primarily a street car. Im thinking
the 35 might spool too late for me to really enjoy it on the street, yet I hate not to
buy cuz its only like 50 bucks more. I dunno, so confused. Im also still looking for
a good manifold that allows me to retain ps and ac. I guess Im stuck with a log
mani, maybe a drag gen 4. Any opinions?
Re: H22 Turbo Setup questions (boostedh22n770)
35 dont look back....... i personally think the 35 is to small for the h i sold mine for this reason
