What Ecu will work with both vtec/nonvtec?
Old Mar 17, 2007 | 08:33 AM
JDMB20TDA's Avatar
Default What Ecu will work with both vtec/nonvtec?
Alright this is kinda confusing but hear me out,
I have a Built b18a and it will soon be a Ls/vtec Turbo, for now it will remain non-vtec untill I have the head built.
What obd1 ecu would I be able to use inorder to minimize problems?
I want to get a vtec ecu so while non-vtec It runs but, it throws some codes, no biggie.
But when the head is bolted Up i wont need to get it tuned right away untill I bolt the turbo up to it.
so pretty much what ecu could I use to run non-vtec, and DOhc Vtec w/o getting a basemap prior to boosting?
Old Mar 17, 2007 | 08:36 AM
tony413's Avatar
get what you need when you need it
Old Mar 17, 2007 | 04:04 PM
JDMB20TDA's Avatar
Default Re: (tony413)
that doesnt answer my question, thanks
anyone else?
Old Mar 17, 2007 | 04:12 PM
katoeh2o's Avatar
Default Re: (JDMB20TDA)
Get a p28 and when you are non vtec just set your vtec above your rev limit. Asuming that your ems will asllow you to do that.
Old Mar 17, 2007 | 05:11 PM
doood's Avatar
been there done that
Default Re: (katoeh2o)
you can disable vtec with just about every ems
Old Mar 17, 2007 | 06:26 PM
93turbo16's Avatar
Just get the P28 now, disable vtec solenoid and the VTP and you should be good to go.
Old Mar 18, 2007 | 11:11 AM
JDMB20TDA's Avatar
Default Re: (93turbo16)
soo I will require a form of engine managment no matter what?
It might just be easier to buy a Ls ecu and than wait.
Old Mar 18, 2007 | 12:55 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB20TDA &raquo;</TD></TR><TR><TD CLASS="quote">soo I will require a form of engine managment no matter what?
It might just be easier to buy a Ls ecu and than wait. </TD></TR></TABLE>
Or you could just get a chipped ecu, have someone program it for the LS, and then when you upgrade to the vtec head, then get it programed for vtec. Instead of buying two different ecus.
Old Mar 18, 2007 | 04:18 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
Or you could just get a chipped ecu, have someone program it for the LS, and then when you upgrade to the vtec head, then get it programed for vtec. Instead of buying two different ecus.</TD></TR></TABLE>
+1
Old Mar 18, 2007 | 05:27 PM
JDMB20TDA's Avatar
Default Re: (mtber)
ill jsut buy self a obd1 Ls ecu and have it tuned for vtec later.
Old Mar 18, 2007 | 05:30 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB20TDA &raquo;</TD></TR><TR><TD CLASS="quote">ill jsut buy self a obd1 Ls ecu and have it tuned for vtec later.</TD></TR></TABLE>
It will still have to be chipped either way.
Old Mar 18, 2007 | 07:51 PM
darrinbrewer's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
+1</TD></TR></TABLE>
+1 again
Old Mar 18, 2007 | 11:13 PM
JDMB20TDA's Avatar
Default Re: (darrinbrewer)
well for now with the non-vtec/non turbo b18a/b it will run fine with Ls ecu.
But yea I thank you guys for your help, being the obd1 ls ecu;s are so much cheaper I think its the smarter route for now...
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
vtechaccord
Mar 14, 2011 03:03 PM
bakoCRX
Oct 20, 2009 01:33 PM
technine
Jan 17, 2008 10:43 AM
Addicted2Racing
10
Jan 27, 2004 04:29 PM
