common turbo problems
Old Mar 19, 2007 | 12:46 PM
cleanej2's Avatar
Default common turbo problems
im considering going turbo n i just wanna know wat the most frequent problems with them are
Old Mar 19, 2007 | 12:50 PM
awdgsx96's Avatar
Default Re: common turbo problems (cleanej2)
With the turbo itself? Engine problems caused by turbo? Or both? The question is vague, what do you mean more specifically?
Old Mar 19, 2007 | 12:54 PM
cleanej2's Avatar
Default Re: common turbo problems (awdgsx96)
any kinda of problems at all.. thats why i made the question so vague
Old Mar 19, 2007 | 01:01 PM
awdgsx96's Avatar
Ok....try a search for turbo (insert motor here ex. b16) or something to that nature, and see what problems you find. But off my head, there are:
- Not enough knowledge of how turbocharging work
- Increased chance at detonation
- Tuning problems
- Finding correct exhaust for your setup
- No support for boost, such as no upraded fuel or engine mangement
- Improperly sized turbo for engine or application
Hope I was some help
Old Mar 19, 2007 | 01:02 PM
Topdawgg's Avatar
problems are usually with the owner, not with the turbo setup itself...
being cheap is a big thing... not spending the proper money on a good tune..
Buying cheap parts to save some money, when you have to replace them in the long run anyways...
Proper knowlege and research is key
you shouldnt be expected to know EVERYTHING, but there are some things you should know and understand before tackling the project...
hope this helps...
I bet anyone on here that has a boosted car can tell you things they would do better next time around... Ive had 3 different setups in my car now, each year.. and im learnin constantly... makin life easier in the long run
Lithel
Oct 1, 2007 06:22 AM
90laser_rst
Nov 19, 2006 05:50 PM
channy
May 13, 2005 06:23 PM
chuckles2
Mar 13, 2005 01:22 AM
Spartanic
Feb 2, 2004 04:04 PM
