Supercharger Help Needed
Old Mar 22, 2007 | 01:04 PM
nicko360's Avatar
* B A N N E D *
Default Supercharger Help Needed
I bought this civic hatch, supercharged d16z6. its a stock motor. the belt on the supercharger looks worn, the guy who owned the car before me kinda neglected the car. Im trying to get maximum preformance out of it, and need some input.
This is what I have done so far:
Walbro 255 fuel pump
RC 370 injectors
I am going to get it chipped on chrome and tuned
what else should I do to maximize preformance without spending a lot of money?
Do I need an aftermarket fuel rail, or will the stock d series hold the hp?
How do I find out the size of my pulleys?
any advice is appreciated
thanks
Old Mar 22, 2007 | 01:05 PM
nicko360's Avatar
* B A N N E D *
Default Re: Supercharger Help Needed (nicko360)
Im running a JR FMU and the map controller
Old Mar 22, 2007 | 01:13 PM
Veris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">I bought this civic hatch, supercharged d16z6. its a stock motor. the belt on the supercharger looks worn, the guy who owned the car before me kinda neglected the car. Im trying to get maximum preformance out of it, and need some input.
RC 370 injectors
thanks</TD></TR></TABLE>
Get chrome/hondata/ubberdata throw out the JR electronics, replace the worn belt, read the JRSC threads here, and measure your pulleys...
Old Mar 22, 2007 | 01:16 PM
nicko360's Avatar
* B A N N E D *
Default Re: Supercharger Help Needed (Veris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Veris &raquo;</TD></TR><TR><TD CLASS="quote">
Get chrome/hondata/ubberdata throw out the JR electronics, replace the worn belt, read the JRSC threads here, and measure your pulleys...</TD></TR></TABLE>
so once I get it tuned I wont need the map controller?
any help is appreciated
Im 17 and dont know that much about superchargers...
Old Mar 22, 2007 | 01:52 PM
nicko360's Avatar
* B A N N E D *
bump
Old Mar 22, 2007 | 04:01 PM
PickleTeg's Avatar
You will not need the Map controller or the FMU if you get standalone tuned. For max performance you will want to get rid of those ASAP. They work but they are not going to give you the best driveability or power. Also...how much boost are you running? What header/intake/exhaust are you using?
Old Mar 22, 2007 | 04:26 PM
nicko360's Avatar
* B A N N E D *
Default Re: Supercharger Help Needed (PickleTeg)
i hooked up a boost gauge, but Im not sure which vacum port to hook it up to. I have it on the throttle body and it only read vacum, not boost. It has an ebay 4 - 1 header, the jrsc manifold, the exhaust is a flowmaster.
Should I just run the fuel lines straight to the fpr??
also i just got my car running, but it doesn't run too good. Is that because the ecu is not chipped for the fuel pump and injectors??
Thanks
Old Mar 22, 2007 | 08:29 PM
PickleTeg's Avatar
WOW! uuhh...for starters if you are running large injectors and a big fuel pump on a stock ecu you will be running rich cause you are dumping fuel in this thing. To run a base setup you need stock injectors/FMU/map controller or relay. To get your car to work right you need to take this thing to someone who knows a little more about these kinda systems. I would find a Honda FI guy ASAP. FYI: your boost gauge needs to see manifold vacuum/boost. The JR supercharger does not make boost near the TB.
Old Mar 23, 2007 | 06:17 AM
nicko360's Avatar
* B A N N E D *
if I sent my ecu in to get chipped for the injectors and fuel pump would that work???
or will I need to take those off to read the fuel pressure and idle rpms?
Old Mar 23, 2007 | 04:41 PM
nicko360's Avatar
* B A N N E D *
put my stock injectors back on
if I read the fuel pressure and idle rpms with the stock injectors will it be the same as with the 370's?
also where should I get it tuned? xencron or intec?? or someplace else??
Old Mar 23, 2007 | 10:39 PM
jeffhaut's Avatar
https://honda-tech.com/zerothread/1214810
read this whole thread, it may take you a very long time, but you will be far better for it. i read the whole thing, collected the parts that i knew i needed for the job along the way, and then when i finished it and had a good grasp of what i was getting into, i slapped it on. no belt issues, no detonation, no prolbems whatsoever. the car runs like a dream and its because i took the time to learn before i started changin stuff
Old Mar 24, 2007 | 06:33 PM
nicko360's Avatar
* B A N N E D *
Default Re: (jeffhaut)
what else should I get before I get it tuned with out spendine a ton of money?
Old Mar 24, 2007 | 06:40 PM
sc4dr's Avatar
Default Re: (nicko360)
Uh, like Jeff said...READ!
Old Mar 24, 2007 | 09:37 PM
nicko360's Avatar
* B A N N E D *
okay I read it, but I still need to know if I should read the info for the basemap with the stock injectors or my rc370s?
Old Mar 25, 2007 | 12:38 PM
nicko360's Avatar
* B A N N E D *
up
jcrredrex2012
Dec 15, 2012 08:24 PM
93egryda
Nov 27, 2007 11:50 PM
93egryda
Nov 25, 2007 06:00 AM
nekoabandoned
Nov 26, 2005 11:28 AM
JDMroyEG5turbo
Aug 10, 2005 01:19 PM
