Drag Manifold + 57 trim = no fit?!?!?!?
i got a b18b and decided to upgrade to a t03t04e 57 trim and it is rubbing a little on the block.... i have a drag manifold
should i shave the block alittle? new manifold? lil help would be cool
thanks all
thanks all
Re: Drag Manifold + 57 trim = no fit?!?!?!? (eggie75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">just shave the block.</TD></TR></TABLE>
Re: Drag Manifold + 57 trim = no fit?!?!?!? (PnoyLSV-T)
most drag mani's are designed around a 5-bolt exhaust turbo, I believe.
A 4-bolt exhaust turbo will not work as they are angled differently from the centerline, therfore, it angles the turbo wrong.
I found this out the hard way too, I ended up selling the drag mani and getting a max-rev as this is one that is designed around a 4-bolt exhaust turbo.
