Typical smoking problem need suggestions
Old Mar 18, 2007 | 12:47 PM
TDCTyler's Avatar
Default Typical smoking problem need suggestions
Ok so its a 97 prelude sh stock internals t3/to4e 10-psi, been like this for 2 years.
Just in the past week the car has been putting out masive amounts of blue smoke (oil).
I have no oil restrictor on this turbo, so its either the turbo or could be my rings.
The car only pushes smoke out of the exhaust after I boost and let off, and only under partial throttle, so what do you guys think?
Old Mar 18, 2007 | 01:04 PM
khmboostedeh2's Avatar
Default Re: Typical smoking problem need suggestions (spOolin97)
As a rule of thumb...
If it burns oil while accelerating, its more likely to be the piston rings.
If it burns oil while decelerating in gear or immediately after doing so, its your valve seals.
If you start the car while cold and it begins to smoke after 5 or so minutes, then it could be the seals in your turbo.
-Kris
Old Mar 18, 2007 | 01:34 PM
TDCTyler's Avatar
Default Re: Typical smoking problem need suggestions (khmboostedeh2)
Cool thanks man, do you think its too late to use a ristrictor? I need to daily drive this car for a few months untill the built motor and new turbo go in, but the way its smoking it will get taken off the road in no time.
Old Mar 18, 2007 | 01:59 PM
From what I understand, the seals in a turbo do not blow. With excess oil flow, the oil is able to push itself past the seals.
I ran an oil line line which was a bit on the larger side on my current turbo. After it started smoking I installed a restrictor and the smoking stopped almost entirely.
Kris
Old Mar 18, 2007 | 02:42 PM
DaveF's Avatar
fwi, a turbo going bad can cause smoke on decel.
Old Mar 18, 2007 | 03:03 PM
Default Re: Typical smoking problem need suggestions (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">fwi, a turbo going bad can cause smoke on decel.</TD></TR></TABLE>
Hmm, I never knew that. How's that work?
Old Mar 18, 2007 | 03:22 PM
DaveF's Avatar
dunno, but i had that problem and never thought it was the turbo... replaced the turbo and the problem stopped..
it was not a heavy smoke... it was faint smoke....
Old Mar 18, 2007 | 04:06 PM
22psicrx's Avatar
remove your down pipe and look for oil or your charge pipe and look for oil. do a compression test, look at your spark plugs.
Old Mar 19, 2007 | 08:30 AM
TDCTyler's Avatar
I will, thanks. I noticed that the car smokes the worse when im on the highway, if I give the car any throttle after letting off it will poor white and blue smoke out the exhaust for a good 10 seconds.
Old Mar 19, 2007 | 09:36 AM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmboostedeh2 &raquo;</TD></TR><TR><TD CLASS="quote">From what I understand, the seals in a turbo do not blow. With excess oil flow, the oil is able to push itself past the seals.
Kris</TD></TR></TABLE>
Turbo seals will blow and then the turbo needs new seals and a simples restrictor isn't going to save it.
Old Mar 19, 2007 | 03:10 PM
Default Re: Typical smoking problem need suggestions (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Turbo seals will blow and then the turbo needs new seals and a simples restrictor isn't going to save it.</TD></TR></TABLE>
From what I have learned, the whole idea of turbo seals blowing is a myth. They do not blow, oil merely makes it way around them. According to volvoclub.org.uk , the seal on the exhaust side is usually a simple piston ring with a small ring gap. The seal on the compressor side is either the same style or a more positive carbon seal similar to an air conditioner compressor seal, or even a water pump seal.
With that said, I think its just commonly mistaken that when people write "blow out the seals" they mean oil is "blowing past the seals." (As opposed to breaking or physically changing the seal's original shape,state.)
Kris
Modified by khmboostedeh2 at 7:50 PM 3/19/2007
Old Mar 19, 2007 | 07:45 PM
nonvtecD's Avatar
I had a restrictor on an old turbo and it smoked and smoked. I replaced the turbo seals but did nothing else with the oil flow and never had the problem again. This would agree with the fact that seals need to be replaced.
myessay
Jan 27, 2012 01:59 AM
2fastek
Oct 6, 2008 08:07 AM
cooltron
Mar 28, 2008 01:54 AM
alex_s817
Mar 14, 2007 06:32 PM
Firstoost
Dec 8, 2005 11:05 PM
