need high quality vacuum hose for turbo
can someone tell me some good brands of vacuum hose that can withstand high heat. i have a turbo in my civic and my existing vacuum lines gets hot, cracks and cause my turbo to not work when air leaks out of them. thanks.
Re: need high quality vacuum hose for turbo (lv6l)
are you using rubber or plastic lines? you could always use the AN/stainless braided as well, if your wallet allows
i am currently using rubber hoses. i have some hoses that my friend gave me and those so far is holding up, but the ones i had are so cheap it cracks within a few weeks of daily driving.
and heheh my wallet does not allow me to go with stainless. i want to stick to plastic or rubber. i am not running with much boost, only 5psi on a t3/t4.
BigMoneyP
09-17-2005 12:04 PM
