update on spueak
Old Jan 5, 2002 | 06:07 PM
95gsr's Avatar
Default update on spueak
ok yeterday i started to hear a noise every time i turned to steering wheel today upon a little investigation it is coming from the front drivers side wheel sound like from behind the rotor. an other thing today i went to go take off one of my wheel and the stupid lug broke the stud. is it a pain to fix i ordered the part. i am pist
thanks
Old Jan 7, 2002 | 05:24 PM
iceburgslim's Avatar
Default Re: update on spueak (95gsr)
Sounds like you have a bad ball joint.
Old Jan 7, 2002 | 07:10 PM
95gsr's Avatar
Default Re: update on spueak (iceburgslim)
you think that is what it is?
Old Jan 7, 2002 | 08:04 PM
Wildohiorice's Avatar
New User
if it was bad ball joint u would notice some aligment problems slight though not major, could be CV joint too
Old Jan 8, 2002 | 03:52 PM
I say lower ball joint/s. In my experience, cv-joints dont normally squeak, they make a horrible 'clicking' noise when you are on the gas while turning. If the front end squeaks when you are not moving, and you just turn the steering wheel side to side, then that is your ball joints...but their are lower and upper ball-joints.It is most often lower ball joints that go bad. You can check your CV boots, and if they are not torn then that pretty much eliminates your CV joints. I hope this is of some help to you, good-luck.
Old Jan 10, 2002 | 07:43 PM
95gsr's Avatar
how much is it for new ball joints and i s it a pain in the *** to install
Old Jan 10, 2002 | 08:58 PM
New User
don't know about the tegs but for my blazer they were 40 bucks for the cheapys and 110 for the lifetime warrenty ones apeice and on my blazer they are a pain in the *** to replace better off having someone else do that repair lol
Old Jan 11, 2002 | 12:35 PM
Default Re: update on spueak (Wildohiorice)
They are around $40 a piece. Like wilohio said, they are a pain to replace. You are better off taking this to a dealer, where they will check which ball joint it is (upper or lower) and they have the proper tools to remove it (ball-joint puller or air hammer). Their are ways to remove them without these tools but it's definitely not easy. Call your local dealer and see how much they charge to do it, that's your best bet. If you have to do it yourself, let me know and I can tell you how. Later!
avio07
Jun 21, 2012 03:25 PM
all-mtr-teg
Nov 28, 2010 10:22 AM
ld1985
Oct 23, 2009 11:14 AM
drumjunkie05
Jan 18, 2009 09:06 AM
