90,000mi
Old Jan 5, 2002 | 07:59 PM
SleepinGSR's Avatar
Default 90,000mi
I just bought a "95" integra GSR it has 90,000mi on it what kind of maintanence am I going to have to consider for this many miles? Someone told me it might need a water pump.....
Peace
Old Jan 5, 2002 | 08:03 PM
91DA9's Avatar
Default Re: 90,000mi (cyb3r sn1p3r)
Make sure the timing belt has been changed.
Other simple things that might not be nescesary but are easy and relatively cheap are: Flush fill radiator, (unless you are changing water pump) change gear oil, check or change spark plugs, check all belts and hoses.
If you need any help or cost estimates of any of the above I would be glad to tell you.
edit: make SURE the timing belt has been changed
[Modified by 94IntegraGSR-OVR, 12:03 AM 1/6/2002]
Old Jan 5, 2002 | 08:07 PM
DmanNYC2001's Avatar
New User
Timing belt, water pump, timing belt tensioner & spring.
(if you skip this maint, your integra will die a rather quick & painfully expensive death.)
My timing belt popped at 95k and I was lucky I knew it would happen.
Also, valve cover gasket set & pcv grommet.
Old Jan 5, 2002 | 08:08 PM
SleepinGSR's Avatar
Default Re: 90,000mi (94IntegraGSR-OVR)
What if the timing belt has not been changed
As far as the others Im not sur yet but the guy Im buying it from is very perticuler about the car it is spotless he even took out the factory floor mats and had after market so the mats dont have 1 stain
peace
Old Jan 5, 2002 | 08:11 PM
91DA9's Avatar
you should just ask him.
If it has not been changed then it is definitely about to break which means BYE BYE B18C1
edit: by the way if you do not know if the other stuff has been done then you should just do it as it is not very expensive and for peace of mind.
BTW: timing belt is about 50 dollars
[Modified by 94IntegraGSR-OVR, 12:12 AM 1/6/2002]
Old Jan 5, 2002 | 08:14 PM
B2FiNiTY's Avatar
I would just do things like that for peace of mind if you can spare the $$$.
Old Jan 5, 2002 | 08:16 PM
SleepinGSR's Avatar
Default Re: 90,000mi (B2FiNiTY)
cool for some reaason I thought you said "timing chain" that is a relief I probably will just replace the belt for "Peace of mind thanks".....
Peace
Old Jan 5, 2002 | 09:15 PM
Sintegra's Avatar
what is the difficulty level of chaning the timing belt (out of 10)? I think i am mechanically inclined, but i have never done this before. I do have a helms manual, does anybody recommend against me going at it myself? Are there any seriouse hazards i may encounter? I did the 60k and brakes by myself btw.
Old Jan 5, 2002 | 09:40 PM
Cow's Avatar
Cow
Default Re: 90,000mi (Sintegra)
C-speed has a tutorial on a timing belt change (http://www.c-speedracing.com/howto/t...elt/tbelt.html). It doesn't sound too tough, just time consuming. You may also need an impact gun. HTH
Old Jan 5, 2002 | 10:12 PM
New User
easy...
you will need:
½" drive socket set.
10, 12, 14, 17 & 19mm sockets.
( 6 point type, else you will have a long fustrating day with 12 point sockets.)
a breaker bar wouldn't hurt...
12 & 14mm box wrench
either an impact wrench or a spool of heavy twine or string.
Hydraulic jack and stand. I wouldn't recommend doing this on the factory scissor jack.
***REMEMBER***
count all tools before starting the job
account for all tools when complete.
a friend of mine...
started and drove his nissan truck with an open end wrench in the tensioner assy.
started (and did not drive) his camaro with a socket wrench on the pulley bolt.
good luck
Jun 17, 2009 05:19 PM
zhen_fai
Aug 25, 2007 07:39 AM
matryx
Jul 16, 2007 04:45 PM
petrv
May 10, 2006 03:24 AM
Quik Chris
Aug 28, 2002 07:17 PM
