Coilover install progress...
Old Dec 29, 2001 | 10:31 PM
Phat Corolla's Avatar
New User
Default Coilover install progress...
Man, I just need to vent. When I started working on installing my coilovers this morning, it looked as though it was going to be a 1.5 (maybe 2) hour job. Well, the fronts went exceptionally well, but when I got to the rears, all hell broke loose. I had two frozen and rusted bolts that broke as soon as I put a decent amt of pressure on them. So...I had to drill them all out and I'm not even quite done with that. I decided to take a break until tomorrow. This shouldn't be this hard!!!!
Old Dec 30, 2001 | 10:18 AM
matthewk's Avatar
Default Re: Coilover install progress... (Phat GS-R)
If you need new bolts for the rear LCA's and you want them today (Acura Parts not open on sunday) here is the size.
M10 x 75 1.25 pitch
Old Dec 30, 2001 | 11:14 AM
New User
Default Re: Coilover install progress... (matthewk)
Dude, you're awesome. I just came in from my garage to take a break from this torture, and was comtemplating how I was gonna find a bolt that would work. Thanks so much!!!
Old Dec 30, 2001 | 11:39 AM
RacingE_Teg's Avatar
Yeah...it's quite common that those bolts seize. If it helps, you ain't the only one that has experienced this problem...
Old Dec 30, 2001 | 11:45 AM
Max GSR's Avatar
Default Re: Coilover install progress... (RacingE_Teg)
Actually that's quite common, not that it's any consolation to you. When I first installed my coilovers, I also had the bolts and bushings so "frozen" that I also had to replace both rear LCA's. Get everything removed before you order bolts tomorrow in case you also need them too! (I'm assuming that's what you were referring to in your "Broken Bolt" post?)
Old Dec 30, 2001 | 11:49 AM
gotnothing's Avatar
Yes, we had the exact same thing happen when we tried to install my springs. Only one bolt broke, but it was also on Sunday and we had to wait 'til Monday to get new ones. Plus, the drill wasn't working very well, and it took like 8 hours to drill out the bolt. Apparently, this happens all the time.
Old Dec 30, 2001 | 11:50 AM
New User
Default Re: Coilover install progress... (Max GSR)
Yeah, it's looking like I might have to replace the LCAs. How much will that cost me?? I unfortunately broke the bolt holding the LCA on to the hub, so that's gonna be a bitch to get out. I'm so pissed at my damn car right now...
Old Dec 30, 2001 | 11:54 AM
New User
Default Re: Coilover install progress... (gotnothing)
The problem is that I have 3 bolts to drill out...it really sucks.
Old Dec 30, 2001 | 11:56 AM
gotnothing's Avatar
Man, that does suck. When we did it, drilling out the bolts was the most annoying part. Having to replace the shock wasn't fun either, since it was 7 am on Monday morning and we only had time to go to Acura. Stock shocks are expensive!
Old Dec 30, 2001 | 11:57 AM
gotnothing's Avatar
And I was saying the same thing you are "This shouldn't be this hard!"
Max GSR's Avatar
If you're gonna have to replace those parts anyway, then I suggest putting a big torch to it! Really! Drilling those hardened bolts is a royal pain, but I guess I don't have to tell you that!
Old Dec 30, 2001 | 12:05 PM
SweetChin's Avatar
well rather then spending a crap load of money on new lca's you should just get new bushings and get the old ones pressed out and new ones pressed in...the bushings are only 30 bucks a piece
Old Dec 30, 2001 | 01:24 PM
New User
Default Re: Coilover install progress... (SweetChin)
Where do i get new bushings??? I am having to drill out the old bolts inside the bushings, and I bet that I'm wrecking the bushings pretty badly.
Old Dec 30, 2001 | 07:48 PM
MattG's Avatar
New User
I am so glad I am doing this work on my car now (2000 GSR). So far no stuck bolts and 1/2 tube of anti-sieze and everything is back together.
You can also try tightening the bolts first. It sounds wierd but it does work (sometimes). Something about the bolt willing to get tighter rather than loose. The motion of the bolt breaks it loose and will let penetrating oil into the threads. Good luck. After hearing your problems I think I am going to pull all the suspension bolts i work on and coat them in anti-sieze.
[Modified by MattG, 8:57 PM 12/30/2001]
Old Dec 30, 2001 | 10:26 PM
Adi Radoncic's Avatar
On Fire!
Phat GS-R you can get the bushings at your local acura dealer as for drilling out the old bolts inside the bushings, I wouldn't even do that just go over to the other side between the busing and the fork of the shock and cut it with a die grinder with a cutting adaper.
Othervise your vaisting time drilling those things out because once you drill them you can't get them out anyways because they are rusted on to the metal sleeve in the middle of the busing....
Old Dec 30, 2001 | 10:53 PM
IntegraGSR23's Avatar
Default Re: Coilover install progress... (newgsr)
When I installed my Comptech springs in my 96 my rears were a pain in the ***. Bolts were rusted and brokeon me. I did the install 3 weeks ago. I just cut the shock so that I was able to remove it and get it out of the way and bought new LCA's
CRVTECSCREAMER
Feb 23, 2009 07:28 AM
b18cEK
May 29, 2007 04:52 AM
droppedcivo
May 20, 2003 05:03 PM
ebelp
Mar 1, 2002 05:16 AM
_noname_
Aug 20, 2001 01:16 PM
