Just did compression test
Old Jan 4, 2002 | 09:35 AM
95gsr's Avatar
Default Just did compression test
check it out
the car is 95 gsr mods are found below
piston
#1 228
#2 233
#3 223
#4 213
you guys think i should worry about the 213? any other thing this is a stock bottom end never been touched. so i guess that is a good thing. so i guess it is good to turbo. woohoo
Old Jan 4, 2002 | 09:41 AM
GQ 05YellowEVO8's Avatar
Default Re: Just did compression test (95gsr)
Those numbers look good, 200 is avg. so you are above avg.
Old Jan 4, 2002 | 09:45 AM
B2FiNiTY's Avatar
They look pretty good. Most of them are close together too.
Old Jan 4, 2002 | 10:20 AM
95gsr's Avatar
the weird thing is that it seems high to be 130k miles on it. but i gues that is a very good thing. and also plugs were white meaning,lean right. so i have b&m adj. fuel pressure reg. and i could turn that up and fix the problem right.
Old Jan 4, 2002 | 10:23 AM
OneThirtyEight's Avatar
Cyl 4 is usually a little higher then the rest, but nevertheless still good numbers.
Old Jan 4, 2002 | 10:26 AM
95gsr's Avatar
Default Re: Just did compression test (97blackteg)
# 1 is the one closest to timing belt right?
Old Jan 4, 2002 | 11:00 AM
MachAF's Avatar
Nominal compression is 270psi at 250rpm with wide open throttle.
minium- 135psi
max variation - 28psi.
Old Jan 5, 2002 | 06:49 PM
Butterbean's Avatar
those numbers are high. Was this at WOT, and did u unplug the fuse for the fuel injection system?
Old Jan 5, 2002 | 07:08 PM
95gsr's Avatar
Default Re: Just did compression test (Butterbean)
yup thats what i'm saying i took out the 15 amp fuse under the hood. and clutch in and gas pedal pressed in to do the WOT and those are the #'s talk about good compresstion at 130 k miles
Junkie
Mar 22, 2008 12:21 PM
Boostin_GSR
May 23, 2007 01:12 PM
Si_chRis
15
May 26, 2006 08:46 AM
turbotime
Oct 1, 2005 08:46 AM
InLimbo87
Jun 22, 2004 07:54 PM
