im getting code 23
Old Dec 30, 2001 | 06:49 PM
smkngsr's Avatar
Default im getting code 23
I was wondering what are the causes of code 23...and what should i check to prevent this from happening...thanks much
B18C-EJ1
Guest
Posts: n/a
Default Re: im getting code 23 (smkngsr)
https://honda-tech.com/zerosearch
Old Dec 31, 2001 | 06:09 PM
1fastGSR's Avatar
New User
http://www.clubsi.com/error_codes.shtml
Old Dec 31, 2001 | 10:29 PM
MachAF's Avatar
Knock Sensor circuit malfunction -
1. Open or short in the Knock Sensor circuit
2. Knock Sensor
3. ECM
1. Do the ECM reset procedure.
a. Start the engine. Hold engine at 3,000 rpm in neutral in no load, until the
radiator fans comes on, then let ie idle.
b. Hold engine engine at 3,000 - 4000 for 10 seconds.
Does it still throw code 23?
If no - check for poor connecttions or loose wires between KS and ECM.
If Yes - Check for shorts in the KS wires. Turn igntion off, disconnect KS, check for contunuity between ECM termails D6 and body ground.
E-mail me if you want more info. I'll scan the page and send it to you. I'm too lazy to type all this trouble shooting info out.
Japankid
May 10, 2009 12:42 PM
mprelude
May 17, 2005 10:25 AM
sir2sol
Apr 1, 2005 04:55 PM
Phatch99
Jul 15, 2004 10:27 AM
