Bolt Extraction Techniques!!!
Old Jan 2, 2002 | 07:12 PM
Phat Corolla's Avatar
New User
Default Bolt Extraction Techniques!!!
All right everybody, lets all post our best bolt extraction techniques. I have some broken bolts and I'm trying to figure out my options here. Lets see what you all have up your sleeves. Thanks!!!
Old Jan 2, 2002 | 07:14 PM
DAYUIZ's Avatar
Default Re: Bolt Extraction Techniques!!! (Phat GS-R)
Buy a Bolt Extractor. There are several kinds. Most come as drill bits, some look like normal drills that just spin the other way. Others look like screwdriver drill bits except at the end they have grooves just for taking out the bolt.
Normally you drill a depression into the offending bolt and then put the extractor there. The depression lets the extractor bite better. Turn and wa-la....bolt comes out.
-Steve
[Modified by DAYUIZ, 8:16 PM 1/2/2002]
OneThirtyEight's Avatar
Drill them out
New User
Default Re: Bolt Extraction Techniques!!! (DAYUIZ)
Explain bolt extractor...
Old Jan 2, 2002 | 07:21 PM
DAYUIZ's Avatar
I did explain it more. I just posted that one line cause I wanted to be first. But someone beat me to it.
-Steve
Old Jan 2, 2002 | 11:42 PM
Adi Radoncic's Avatar
On Fire!
Phat GS-R
Let me ask you this what bolts are broken and please tell me exactly.
I just got done doing this about a month and a half ago and I think I can help.
So le me know
Old Jan 3, 2002 | 06:59 AM
New User
Default Re: Bolt Extraction Techniques!!! (newgsr)
I have 3 broken bolts on the rear LCA assembly. Each bolt holding the shock to the LCA is broken. This doesn't worry me. What does annoy me is the broken bolt I have connecting the LCA to the hub assembly. This would be a pain to drill out. Anyways, I went and bought an angle grinder and some cutting wheels to see if that'll work. I think it might. If you have any other suggestions, please do tell...Thanks a lot.
Old Jan 3, 2002 | 07:11 AM
samagon's Avatar
the bolt extractor I have, I need to drill more than just a dimple.
I drill down into it, put in my tool and start twisting.
if worse comes down to worse, i will heat up the metal around the stuck bolt, this sometimes expands the metal enough to get the bolt out.
Old Jan 3, 2002 | 07:35 AM
New User
Default Re: Bolt Extraction Techniques!!! (samagon)
Oh, I also bought a hardcore propane torch. It's got a wand that connects to a propane bottle and an oxygen bottle. It should be useful for getting bolts un-stuck.
87CRX
Aug 30, 2008 05:59 AM
spidermancivic
Aug 11, 2007 08:17 AM
sidious141
Aug 27, 2004 07:13 PM
