Knocking
Old Jan 1, 2002 | 12:00 PM
Adampops's Avatar
Default Knocking
I did a search and i cant find what i want. At idle and lower rpm's (maybe higher rpm's, but the engine noise overpowers it) i hear a knocking sound. It only happens when the car is cold though. Once it heats up the sound goes away. Does anybody know what this could be???
Old Jan 1, 2002 | 12:04 PM
DmanNYC2001's Avatar
New User
Default Re: Knocking (Adampops)
sound of taps...
spun bearing, piston slap...
how many miles are on the engine?
Old Jan 1, 2002 | 12:05 PM
Phat Corolla's Avatar
New User
So is this Engine Knock we're talking about, or is it some random mechanical sound? If it's engine knocking, check your timing and/or use some higher octane gasoline. Sorry, but I have no other suggestions.
Old Jan 1, 2002 | 12:10 PM
Adampops's Avatar
Default Re: Knocking (DmanNYC2001)
it has 116,000 miles on it. its a 94 RS
Old Jan 1, 2002 | 12:11 PM
Adampops's Avatar
yes, it is the sound of tapping. Its like tap tap tap tap tap tap................
ohhh, and i dont know if it goes away when the engine wharms up for sure, maybe i just get used to the sound and dont think about it!
Old Jan 8, 2002 | 06:52 PM
CRuiser-X's Avatar
It could be the throw out bearing in your tranny, i had the same problem in my crx, actually they said at first it was the throwout bearing but after that they said it was something else, and i had to say hello to an all new tranny
Old Jan 8, 2002 | 07:26 PM
MachAF's Avatar
I suggest you try some higher octane gas.
Old Jan 8, 2002 | 10:51 PM
Vtec integra's Avatar
si all the way. for an all motor ls you'll be getting a tuned ecu and raise your redline sooner or later
Old Jan 9, 2002 | 09:32 AM
fuguman's Avatar
New User
i have a 95 rs with 103K on it and it sorta does the same thing
the knoking sound can be heard at idle right? and its sorta ticking too?
i had the noise louder even when warm but after i adjusted my valves it sounded better cold and the noise was gone when it is warm
i'm gonna readjust the valves again soon cause i'm not sure if i did them good enough, maybe the sound will go away when its cold too
let know if you find that its something serious
Victor Pereira
Honda Fit
May 12, 2019 07:57 AM
jhammond_82
Oct 16, 2009 10:53 AM
thesilverfox
Aug 20, 2007 10:10 PM
redliner8000
Feb 19, 2004 08:49 PM
obsidianG35
Sep 4, 2003 08:55 AM
