secondaries with hondata
Old Dec 30, 2001 | 02:47 PM
Brian_92GSR's Avatar
New User
Default secondaries with hondata
When I got my hondata 4b I lost control of my secondaries. How would I go about putting in an rpm activated switch to control them now?
Old Dec 30, 2001 | 07:46 PM
prospeed's Avatar
Default Re: secondaries with hondata (Brian_92GSR)
Hi it depends on your ecu. Which ecu are you using? You need the Gsr ecu (p72) to keep your secondary butterfly. Im a Hondata dealer if you need any help just email me. Thanks.
Old Dec 30, 2001 | 10:18 PM
New User
Default Re: secondaries with hondata (prospeed)
I have a P61, which is what I plan on keeping. I've read that I can hook up a rpm activated switch to the solenoid that controls the secondaries, but I don't know how exactly to do that (I'm not really sure where that solenoid is).
Old Dec 30, 2001 | 10:35 PM
prospeed's Avatar
That is why it won't work. Im guessing you have a 94 and up gsr then in your car. If you want to hook it up to a rpm activated switch the solinoid is located underneath the intake manifold. It should be a black box. Hope that helps.
Old Dec 30, 2001 | 10:53 PM
New User
I've got a 92. I'll check tomorrow and see if it is in the same place. Where should I check out to get a switch to control it?
Old Dec 30, 2001 | 11:23 PM
prospeed's Avatar
Do you have a 92 gsr motor in your car? the original motor? If so then you dont have secondary butterflies. Let me know if you have the b17 or b18c?
Old Dec 31, 2001 | 07:08 AM
MrFatBooty's Avatar
Unless you have a B18C1 in there, your intake manifold doesn't have secondaries. Does your engine look like this? That's my completely stock B17. If your intake mani looks the same, there are no secondaries.
digital sol
Jul 27, 2006 05:15 PM
BsmoothR
Apr 29, 2006 08:17 AM
Unjockable
Mar 29, 2005 04:08 PM
seen4ever
Dec 15, 2004 04:24 PM
flip1199
Jun 18, 2003 07:02 AM
