Header Bracket on engine block necessary?
Old Jul 15, 2003 | 07:09 PM
HudsoN's Avatar
Default Header Bracket on engine block necessary?
I've done a little research and so far I have found that SMSP, JG Edelbrock, JDM ITR, and Spoon headers do not use this bracket that bolts the bottom of the header to the block.
Is use of this bracket absolutely necessary for a reliable street setup?
What is its function?
Old Jul 15, 2003 | 09:23 PM
99silverbullet's Avatar
Default Re: Header Bracket on engine block necessary? (HudsoN)
Took mine off, I've heard that with a header it will rattle. hth.
Old Jul 15, 2003 | 09:29 PM
kr3wusa
Guest
Posts: n/a
Default Re: Header Bracket on engine block necessary? (99silverbullet)
its there for a reason but i didnt use mine...no problems at all
roydogg's Avatar
It's supposed to keep the header from bending when it gets real hot. But I took mines off.
Old Jul 15, 2003 | 10:02 PM
cccccccc's Avatar
my new 4-1 headers didnt have it
havent had any probs yet
Old Jul 16, 2003 | 03:53 AM
SicNA94TegGsR's Avatar
Swollen Member
I had a POS greddy header that was recommended to me a few years ago, that the bracket was in the wrong place, so I COULDNT mount it, it was a 2 piece 4-2-1, and it would break about evrey 2 or so mos, and I would have to remove it and replace the gaskets. Untill finaly I got my hands on a welder, and replaced the stupid piece. Now I have done several races on it and it has been fine. lol...this is half for info to you, and half to vent what a POS product Greddy makes, and then no customer service number that I can find
Old Jul 16, 2003 | 05:38 AM
Rory Breaker's Avatar
Default Re: Header Bracket on engine block necessary? (SicNA94TegGsR)
It isnt necessary, but in some cases with 2 piece headers it can prevent gasket blowout between the 2 pieces.
I dont think it matters...if your header doesnt have a bracket, its no big deal at all.
Old Jul 16, 2003 | 09:49 AM
HudsoN's Avatar
Default Re: Header Bracket on engine block necessary? (newgsrdriver)
Are there any other companies that make headers without the bracket?
Spoon header without bracket:
[IMG] http://www.ipsracing.com/image...r.jpg [/IMG]
Toda header with bracket
Old Jul 16, 2003 | 09:50 AM
HudsoN's Avatar
[IMG][/IMG] http://www.ipsracing.com/image...r.jpg
Old Jul 16, 2003 | 10:40 AM
Aaron M's Avatar
i have read that these brackets end up cracking and just cause rattles.
Old Jul 16, 2003 | 10:56 AM
StyleTEG's Avatar
Default Re: Header Bracket on engine block necessary? (SilverB18C1)
I think the bracket is more or less there because the stock manifold is cast iron and weighs a ton. Aftermarket headers are quite a bit lighter, so it shouldn't be much of a problem.
The spoon header specificly is very light.
Old Jul 22, 2003 | 01:20 PM
HudsoN's Avatar
Does anyone else have any comments to share?
Old Jul 22, 2003 | 02:09 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicNA94TegGsR &raquo;</TD></TR><TR><TD CLASS="quote">I had a POS greddy header that was recommended to me a few years ago, that the bracket was in the wrong place, so I COULDNT mount it, it was a 2 piece 4-2-1, and it would break about evrey 2 or so mos, and I would have to remove it and replace the gaskets. Untill finaly I got my hands on a welder, and replaced the stupid piece. Now I have done several races on it and it has been fine. lol...this is half for info to you, and half to vent what a POS product Greddy makes, and then no customer service number that I can find </TD></TR></TABLE>
i just got one and it mounts to my block fine.
Old Jul 28, 2003 | 09:19 PM
mowry's Avatar
I'm having the rattling problem with my DC Ceramic 4-2-1...that, and the f*$%n shoulder bolts are $20 each from Acura... Has anybody noticed problems with the DC headers not lining up correctly with the cat? In order to make mine bolt up, I had to shove the cat around a lot, and the flanges just aren't nice and even...call me compulsive, but it's leaking a little bit (it stops for ~3 days after i tighten it up) and just generally doesn't meet my standards. Should I just warranty the thing and tell them to give me one that's bent straight?
Thanks
Matt
Old Jul 29, 2003 | 04:32 AM
JimBlake's Avatar
Default Re: Header Bracket on engine block necessary? (mowry)
I've got a DC 4-2-1 on my GS-R & it fit up OK. It's been about 13 months & 13k miles & it doesn't rattle yet.
PS the bracket holding the OEM manifold to the block wouldn't fit on the DC header so I didn't use it.
Old Jul 29, 2003 | 06:46 AM
mowry's Avatar
Default Re: Header Bracket on engine block necessary? (JimBlake)
Thanx Jim--that's encouraging. I think I just have a screwy header...the way it lines up with the cat is just not right. Good thing I bought it locally. I'll keep you posted.
silentdeath12886
Oct 28, 2006 08:37 PM
xhatchracerx
Oct 11, 2006 05:49 PM
mecca
Apr 18, 2004 06:52 AM
Tommy_Gunns
Jun 6, 2002 04:23 PM
