F-up teg. help
Old Jul 16, 2003 | 04:27 PM
bgx9ner's Avatar
Default F-up teg. help
my radiator busted while on a trip. the nearest town was only about 10 miles away. i didn't want to keep driving but after nagging from my girl and company, i thought i could make it. well after anout 5 miles and driving in the red temp gauge. i called it quites. now it takes a long time to start it. it idles about 100 rmp and is really rough. it dies if i don't keep reving it. its an automatic. what else should i check for. i got a new radiator and still same prob. is it the tranny? why is it idling so rough? help thanks. its a 93 2nd gen integra ls automatic.
Old Jul 16, 2003 | 04:31 PM
mr.beeks's Avatar
Default Re: F-up teg. help (bgx9ner)
after driving like that
you bent your valves
so its time to change your valves or even better
buy a complete head that its more cheaper
for about $50. to $150.
do the math just about 12-15 for each valve times 16
Old Jul 17, 2003 | 06:36 AM
BlackB18CTeg's Avatar
Default Re: F-up teg. help (francisco flores)
10 miles with a busted radiotor is not the greatest idea......... shouldn't have listened to them, but yeah, most likely your valves...
Old Jul 17, 2003 | 07:51 AM
VTECPWR's Avatar
Default Re: F-up teg. help (BlackB18CTeg)
Check and see if there is any coolant in your oil. You can warp the head.
Old Jul 17, 2003 | 12:40 PM
bgx9ner's Avatar
Default Re: F-up teg. help (VTECPWR)
ok i thanks i will. i'm going to get it towed to my house soon. i'm going to take it into the shop for them to look at. they will do a compression test for me. thanks guys.
Old Jul 17, 2003 | 01:05 PM
dont pay for compression check..... so easy to do ur self..... but i guess if your in that situation.....
Old Jul 17, 2003 | 01:52 PM
ltho1998's Avatar
Uhm. sounds like you really fucked up your motor. You should have not let it get into the red for anywhere near that long.
In all probability, you warped your head, at least. Your valve seals are toasted, lord knows what else could have happened.
Shouldn't have listened to them, but live and learn. Make them pay for the damage.
Old Jul 17, 2003 | 04:40 PM
bgx9ner's Avatar
i don't have the tool for that, thats why i'm going to take it in. i don't think they'll charge me. what else should i have them test for?
Old Jul 17, 2003 | 05:49 PM
Loveless's Avatar
leak down?
Old Jul 17, 2003 | 05:52 PM
romeo619romeo's Avatar
Default Re: F-up teg. help (Loveless)
have them pay for the damages
Old Jul 22, 2003 | 11:02 AM
Default Re: F-up teg. help (romeo619romeo)
update?
Old Jul 24, 2003 | 04:51 PM
bgx9ner's Avatar
here's the update. i just towed it home about 2 days ago. i started it up to see if it still had problems. i did this about 5 times. 4 of five was normal. it idled ok too. i haven't really drove it yet, just from the street into my garage. and it was doing fine. i just got done taking out the old radiator. i'm waiting for the new one to come. it will be a week i think. taking it out was a pain. i hope putting it in will be easier. i'll update again when i put in the new radiator and try to drive it. oh, before i took out the old radiator, i flushed the cooling system. the car was on for five minutes and sounded normal. what i think happened was. when the radiator busted it let a bunch of steam and water in the intake and distributor. since then i think it dried up. thanks for caring guys.
Old Aug 1, 2003 | 10:19 PM
bgx9ner's Avatar
new update. i got the new radiator in. still runs bad. these are the symtoms, the oil is milky, the outlet on top of engine that recycles into the combustion is steaming out a mixture of oil and antifreeze, the third cylinder is bad. what can be the problem? cracked head? bent valves? blown head gasket? warped head? how much do you think it will be to fix? is there a good resource for me to check out if i want to try to do it myself? thanks gang
Old Aug 1, 2003 | 10:22 PM
this is just me... but if everything is THAT bad, I would take it too a shop unless you feel VERY confident about ripping apart your block and head... thats just MHO....
Old Aug 1, 2003 | 11:19 PM
Jay J's Avatar
Prince of Zamunda
Well I know a person who did that for 40+ miles on a 2.2L toyota
Old Aug 1, 2003 | 11:20 PM
Jay J's Avatar
Prince of Zamunda
Default Re: F-up teg. help (neuspeed)
He did no damage to it BTW what color is the coolant in the car now
Old Aug 2, 2003 | 07:22 AM
f1uxx's Avatar
goodluck
Old Aug 2, 2003 | 07:26 AM
StyleTEG's Avatar
Default Re: (f1uxx)
Sounds like the head is warped to me.
Milky oil = coolant + oil mixture.
Old Aug 2, 2003 | 07:32 AM
Jay J's Avatar
Prince of Zamunda
when you refilled the coolant did you take the heater hose off and let the coolant top off
dmon
Honda Ruckus and Scooters
Aug 27, 2014 04:30 PM
ozh_hawaiian
17
Jul 12, 2010 10:55 PM
VTEC_PRODUCTION
15
Jan 25, 2009 11:12 AM
k_lude
Dec 14, 2006 09:33 AM
redteg1
Feb 26, 2003 05:57 PM
