oulThrowing code 67 ... Catalyst problem
Old Jul 17, 2003 | 07:27 AM
Mark's Avatar
*Bounty Hunter*
Default oulThrowing code 67 ... Catalyst problem
Would this have anything to do with me hacking out my cat converter? Also how could I go about getin rid of the code, and does it stop my VTEC from engaging?
Old Jul 17, 2003 | 07:34 AM
dohc-nyne's Avatar
Default Re: oulThrowing code 67 ... Catalyst problem (94BlackCivicEX)
did u try reseting ur ecu after u hacked? if u really have a 94 ex it wouldnt matter if u hacked it....or is it a different car ur talkin about? if its ur dc2 in ur sig then yeah it could be cause u hacked it....it could be cause ur cats not gettin enough heat....cats need heat to function an read normal readings...or it will go into limp mode....and vtec doesnt work in limp mode get an o2 simulator or a high flow cat instead of guttin
Old Jul 17, 2003 | 07:45 AM
Mark's Avatar
*Bounty Hunter*
Default Re: oulThrowing code 67 ... Catalyst problem (dohc-nyne)
Where can i get the o2 stimulator? Yeh its for the teg
Old Jul 17, 2003 | 07:48 AM
dohc-nyne's Avatar
ive only seen em for sale online ....u might find someone on here sellin one....google search it u will get a lot of results and info
Old Jul 17, 2003 | 08:03 AM
Mark's Avatar
*Bounty Hunter*
Default Re: (dohc-nyne)
Since im throwing a code, would it be better to make a test pipe? Ive got some friends at a Speedy that could make me one, sadly I already trashed the cat...Will I still throw codes with the test pipe?
Old Jul 17, 2003 | 08:15 AM
dohc-nyne's Avatar
yeah definetly cause with obd2 there has to be some kinda secondary o2 reading so u can either tap it with an o2 simulator or convert to obd1
people might give u **** about polutting the earth though lol....u definetly wont pas smog so keep ur stock cat or get a stock cat for smoging
trav143
Jun 9, 2008 07:08 PM
krashoveride
Honda Civic (2001 - 2005)
Oct 2, 2007 05:20 AM
drowzysleeper
May 10, 2005 01:55 PM
travizx0r
May 4, 2004 04:14 PM
VTEC-DA
Aug 15, 2002 11:04 AM
