GSR motor bogging down...need help...?
Old Jul 13, 2003 | 06:24 PM
leadfoot's Avatar
Default GSR motor bogging down...need help...?
i just recently dropped a GSR motor into my 93 civic coupe, and whenever i take off in first gear it seems to bog down for a second and then it opens up. does any one know what my problem might be?
Old Jul 13, 2003 | 06:35 PM
stnwag0n's Avatar
Default Re: GSR motor bogging down...need help...? (leadfoot)
any check engine lights?
Old Jul 13, 2003 | 06:41 PM
patdemps's Avatar
Default Re: GSR motor bogging down...need help...? (turb0accrd)
check everything you did over again. make sure everything is where its supposed to be. do you have a vafc? If so did you change the vtec engagement? Where is your vtec at?
Old Jul 13, 2003 | 10:27 PM
leadfoot's Avatar
no, no check engine lights.
it did have a check engine light come at first, but i ran the knock sensor wire to the ecu and it went away.
when i let off the clutch and slam on the gas the car seems to hesistate for about 2 seconds and then it kicks.
Old Jul 13, 2003 | 10:29 PM
leadfoot's Avatar
Default Re: GSR motor bogging down...need help...? (patdemps)
no, i don't have a VAFC
Old Jul 13, 2003 | 10:35 PM
OneThirtyEight's Avatar
not enough fuel... thats what it sounds like.
Old Jul 13, 2003 | 11:05 PM
DOMKID's Avatar
sounds like the TPS. get a multimeter/voltage reader and check the voltage in DC at idle and WOT. it should be .5 at idle and 4.5 at WOT.
Old Jul 13, 2003 | 11:07 PM
Default Re: GSR motor bogging down...need help...? (Dominican_Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominican_Kid &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the TPS. get a multimeter/voltage reader and check the voltage in DC at idle and WOT. it should be .5 at idle and 4.5 at WOT.
good idea
Old Jul 16, 2003 | 12:00 PM
pHaNt0m0o0o's Avatar
New User
in case u still havent gotten an answer... be a little more specific? if you are gunning it (gas all the way down) from low RPM's and it bogs under 4k might be the ignition. check the ignition coil bc those can slowly go bad causing bogging at low rpm and it only gets worse. easy fix though.
Old Jul 16, 2003 | 12:14 PM
E-Rok's Avatar
EPIC TUNING
Default Re: GSR motor bogging down...need help...? (pHaNt0m0o0o)
i have the same problem, after a minute the car drives fine.
Old Jul 17, 2003 | 05:05 AM
leadfoot's Avatar
Default Re: GSR motor bogging down...need help...? (97blackteg)
tps is fine. .5 volts at idle and 4.6 at wot
Old Jul 17, 2003 | 05:28 AM
leadfoot's Avatar
my rpm gauge hasn't worked since the swap, so i don't know the exact numbers...i am still trying to fix that problem too. i think it's the wiring at the distributor. maybe because i have an obd 2 distributor (2000 model) , in an obd 1 car, but i am not sure if i need to change to an obd 1 distributor or change a couple of pins around at the connector or it shouldn't matter. any help on that?
as far as the coil, i still have the stock internal coil, should i convert the an external coil like msd ? if yes, how do i do that? if no, how should i check the stock coil?
also, someone said that it might not be getting enough fuel. i change fuel pump on my civic to a gsr fuel pump but i haven't changed the fuel pressure regulator, do you think that i need to?
any help from out there would be greatly appreciated!!!
i just want my car to run like it was meant to run.
Old Jul 17, 2003 | 06:28 AM
Be3LiCiOuS's Avatar
check ur plugs...
Old Jul 17, 2003 | 06:35 AM
leadfoot's Avatar
Default Re: GSR motor bogging down...need help...? (Be3LiCiOuS)
they are fine. i checked them already.
an_eg2nv
Aug 22, 2018 05:48 AM
93DA9
Jun 1, 2008 07:44 PM
gtec28
May 18, 2007 07:13 AM
calvinx29
Jun 29, 2006 02:51 PM
turbochargeb18c
Jul 14, 2005 06:45 AM
