2000 integra which sensor is this?
Old Jun 27, 2011 | 05:43 PM
jimburt3rd's Avatar
Default 2000 integra which sensor is this?
Mm CEL is on and the only code it's throwing is p0113 which is intake air temperature 1 curcuit high. one of the sensors isn't plugged in and im thinking it's the intake sesnor which plugs deirectly into the intake can some one please tell me what sensor plugs into this? more info tomorrow if needed after i ask my teacher what else this is connected too.
Old Jun 27, 2011 | 05:54 PM
sik96teg's Avatar
Default Re: 2000 integra which sensor is this?
That looks like the plug for the IAT or the IACV plug. Can you take a pic of the top of your intake manifold and in between the mani and firewall.
Old Jun 27, 2011 | 06:01 PM
jimburt3rd's Avatar
yeah ill post them now and it does plug into the IAC valve but then split's into that sensor and a tube
Old Jun 27, 2011 | 06:05 PM
jimburt3rd's Avatar
sorry if there bad it's dark here
Old Jun 27, 2011 | 06:06 PM
sik96teg's Avatar
under the mani the only sensors that use that plug that i can think of would be the IACV, IAT, Sensor in thermostat housing and i believe the evap sensor on the bottom of the mani. Most people mix up the IACV and IAT plug so you can try swapping them too.
Old Jun 27, 2011 | 06:09 PM
jimburt3rd's Avatar
I think it's the IAT cause I have the password jdm carbon fiber intake "whales *****" and the sensor wouldnt reach so the kid took the sensor off so guess i just gotta buy a new extended one? and theres and extra tube attached to the same thing you know what thats too
Old Jun 27, 2011 | 06:10 PM
sik96teg's Avatar
if you have a helms manual i believe it states the colors of the wires to ensure you have them plugged into the right spot. Also do you still have your ac and power steering in your car. I will go look at my connectors here in a bit once my car cools down.
Old Jun 27, 2011 | 06:15 PM
jimburt3rd's Avatar
yes i have PS and AC. there is nothing plugged into the hole on the intake if that helps with anything and if you could could you maybe get a pic of those sensors and whatever one you have running to the intake on password jdm they have a picture of a tube going from the intake to the valve cover?
Old Jun 27, 2011 | 06:17 PM
sik96teg's Avatar
nvm about the ac/ps thing there is another connector like that under the mani for the ps but that one is near the brake reservoir.
Old Jun 27, 2011 | 06:22 PM
sik96teg's Avatar
yea that hole is for the ventilation line from the vc to the intake. If your missing the piece from the intake piping you can get a vac line kit from Orielly's that has an assortment of plastic O rings and fittings. I dont have that intake my car is boosted but on the dc2 thats the only thing that would use a hole in the intake piping. Some car or some people use it for an IAT sensor.
Old Jun 27, 2011 | 06:24 PM
jimburt3rd's Avatar
so would the IAT sensor which im missing plug into the intake or somewhere else cause i nthe picture theres just a tube going from the VC to the intake and nothing else
Old Jun 27, 2011 | 06:53 PM
sik96teg's Avatar
Aight so i checked mine and the unplugged one is either for your IACV which is on the back of the intake manifold. The sensor has 2 coolant lines on the bottom of it and a plug on the bottom of it or its your IAT sensor plug and the plug on the top of your intake manifold is for your IAT. Its the sensor with 2 screws right in the middle of your intake manifold.
Old Jun 27, 2011 | 06:55 PM
sik96teg's Avatar
the other plugs with the same connector arnt connected to the same wire loom so it has to be one of those 2.
gitarman2
May 7, 2013 08:55 AM
lojackgsr
Jan 16, 2007 10:35 AM
Used2beAb16
Mar 22, 2005 12:18 PM
ccivic
Jan 25, 2005 11:34 AM
