What code is this?
Old Jul 14, 2011 | 04:27 PM
csmith21's Avatar
Default What code is this?
I keep getting 68, which isn't a cel at all. Anybody else able to get something I may be missing? It comes on at 5500rpm right after a fuel cut.
http://s132.photobucket.com/albums/q...t=d8bcf604.mp4
Old Jul 14, 2011 | 05:21 PM
thewrai6th's Avatar
Default Re: What code is this?
What ECU are you running?
What's your setup?
Old Jul 15, 2011 | 07:12 AM
csmith21's Avatar
P28 ecu, Gsr basemap
Gsr block, LS crank, LS eagle rods, wiseco 9.5:1 pistons, b16 head.
Old Jul 15, 2011 | 10:05 AM
thewrai6th's Avatar
Your ECU has gone nuts, try burning a new basemap, or try another ECU if you have one.
Keep in mind the GSR map is tuned for secondary intake runners.
This should probably be moved the Engine Management and Tuning forum.
Old Jul 16, 2011 | 04:27 PM
csmith21's Avatar
I switched to a b16 basemap, and all was fine. I think it was the secondaries causing some problems.
EKIM NART
Feb 22, 2006 06:56 AM
juicy629
Dec 7, 2005 12:57 PM
Mires
Jul 10, 2003 10:15 AM
