starting problem!
Old Jul 11, 2011 | 01:56 PM
jeryhawj's Avatar
Icon2 starting problem!
help guys!
for no reason.. after parking my car for 4 days without driving... it wont start... will crank but wont start.
can someone help clarify if my timing jumped off a couple teeth before parking?
while sitting in the car you can see the timing belt trying to rotate and the engine is shaking hard. (just recently did a b18cR swap a month ago)
any help is appreciated. thank you.
Old Jul 11, 2011 | 02:27 PM
Hidenplanvew's Avatar
Default Re: starting problem!
Have you tried to jump start it? Might not have enuff juice to actually start... Check fuel spark air
Old Jul 11, 2011 | 05:32 PM
jeryhawj's Avatar
shouldnt need to jump start... since i just got done recharging battery at autozone... but...i guess i could give it a try... bleh...
new update...took off ac and ps belts... and still no new results... i have brand new ngk spark plugs and wires...and i even tested them to make sure they worked...
can someone tell me how to check my fuel system? i have a pretty new walbro 255lph fuel pump... but when i did engine swap... i didnt change fuel injectors and i didnt replace o-ring seals... doesnt leak so i didnt mind buying some new seals... ohh yea... i already bled my fuel line... so...
how do i check if the injectors are thee culprit?
Old Jul 11, 2011 | 08:36 PM
jeryhawj's Avatar
well... another update... just got done trying to jump start it... still no affect towards making car start.. just keeps cranking... and there is a strong smell of gasoline... >.<' help please...?
Old Jul 11, 2011 | 08:52 PM
Oreo-TeCk's Avatar
if theres gas coming from the exhaust ..then it'd be a bad dizzy
Old Jul 12, 2011 | 09:08 AM
jeryhawj's Avatar
no gas coming from exhaust. any other help? x]
Old Jul 12, 2011 | 04:31 PM
Oreo-TeCk's Avatar
gas doesnt have to be pooring out of the exhaust ... but if u smell gas its more then likely the dizzy because its ur getting no spark to burn the fuel
Old Jul 13, 2011 | 09:44 AM
jeryhawj's Avatar
well i did the check for the spark plug wires already though. made my brother crank the engine and i stuck a spark plug into my wire and aimed it at a ground and it sparked... but i guess if you guys say so... ill just swap it out with my gsr dizzy... xD and ill keep you guys updated. thanks for all help so far.
fire_king
Engine Management and Tuning
Mar 8, 2012 02:45 PM
feava510
Feb 15, 2009 10:59 AM
dc2doi
Jan 6, 2008 01:43 PM
yc_dc4mar
Feb 24, 2007 11:57 AM
lazykiwi
May 13, 2004 11:55 PM
