Speedometer Problems
Old Jul 16, 2011 | 08:47 AM
jhvang's Avatar
Icon3 Speedometer Problems
Hey guys/girls, I recently came by an 93 integra i want to buy but the RPM's on the speedometer has been going crazy and i don't know how to explain it or how to fix it. I don't know how much it will cost or what the real damage is to the car. The car idles fine and runs great. The speedometer just goes crazy. If you guys can help me out it would be great! thanks.
Heres an example on YouTube: http://youtu.be/BCYAokALEeQ
Old Jul 18, 2011 | 10:34 AM
flyjazz's Avatar
Default Re: Speedometer Problems
I've got an occasional similar problem with my speedometer,unlike the video where it's the tachometer. Now and again it will stick at 0 on initial driving or jump around erratically and correct itself while driving,especially if I swerve the vehicle. I'm sure there is someone on this site that can explain this behaviour.
Old Jul 18, 2011 | 11:19 AM
mouab18c1's Avatar
So are you referring to the RPM needle or Speedo? Jumpy RPM needle can be a bad ground at your thermostat or bad ignition coil.
Jumpy speedo can be a bad speed sensor or corroded speed sensor plug.
Old Jul 22, 2011 | 08:53 AM
flyjazz's Avatar
Thanks for the opinion on the jumpy speedo. I've ordered a new speed sensor for less than $20 and will give it a try. Looking at the plug,I didn't see any corrosion as it looked spotless when I removed it.
Old Jul 22, 2011 | 11:53 AM
TOO MUCH TORQUE's Avatar
ignition control module
Old Jul 23, 2011 | 04:49 PM
justinsbg's Avatar
What kind of car do you have? If the VSS isn't the problem then most likely the problem is with the speedo PC board. If you need any help diagnosing/repairing the speedo circuit let me know. I'm a Honda/Acura tech in NC full time and repair elecronics in my spare time. I can repair your speedo with quick turn around time and for a good price.
Leandro Peņa
Honda Civic (2001 - 2005)
Sep 26, 2018 08:32 AM
clean3two3
Nov 16, 2007 10:37 PM
black sohc civic
Jan 17, 2004 07:04 PM
black sohc civic
Jan 17, 2004 06:16 PM
