Transaxle drop help
Old Jun 27, 2011 | 02:04 PM
ShIntegra1993RS's Avatar
Default Transaxle drop help
I just recently changed out the clutch disc and pressure plate, also the throw out bearing in a 1993 integra rs 1.8. I have put all of it back together but now i have some problems im not to sure about.
First off everytime i came to slow down it feels like it grabs and lets go on the driver side and when the car slows to a stop it bounces a tiny bit.
Second speedometer needs hooked up. doesnt work. dont know how.
third. the car seems to be bogging out like a vacum line is off the car and the car rev limit wont let the engine hit over 3500 RPMs . you have to shift before 3500 or it rev limits the engine out. But the car definatly doesnt sound like it did before.
fourth and finaly the clutch doesnt seem like it is working right you have to let off of the clutch half way even for it to start engaging but then it feels like you pop the clutch because it is so touchy but not to the floor like it should be.
Please help me with these problems guys.
Old Jun 27, 2011 | 02:14 PM
fcm's Avatar
fcm
Old Fart
Default Re: Transaxle drop help
Sounds like car is in "limp" mode, check for codes, reset ECU/ECM.
There may be a problem in how clutch was replaced, [installation].
Are you sure you have the correct clutch, pressure plate and throwout bearing?
Have you adjusted the clutch cable and pedal? 94
Old Jun 27, 2011 | 03:38 PM
I havnt reset anything but i have adjusted the cable up and down the line and it doesnt really change but make it worse. I havnt touched the actual pedal in the car.
And yea we had to replace the bell house casing because there was a crack. We put in a stage 2 clutch and new pressure plate and bearing. it all was working smoothly before installation. .
Old Jun 27, 2011 | 04:36 PM
UPDATE: I found out the problem in the bogging a small electrical switch disconnected...
Only problem im facing now, is a hard grabbing shaking brake when i brake.. shakes whole front end.. seems like driver side.. grabs and bounces it seems.. but doesnt pull the car when i brake.
Old Jun 27, 2011 | 09:12 PM
64 views and no one can help me out a little here? Just trying to get this car going again.
Old Jul 4, 2011 | 05:34 AM
This site and everyone on it seems USELESS
Old Jul 4, 2011 | 05:45 AM
fcm's Avatar
fcm
Old Fart
Gee, no response over the long weekend, I guess we all should have put our holiday plans on hold so we could spoon feed you info you could probably have found searching here or Googling it, us all being useless I guess. 94
Old Jul 4, 2011 | 06:27 AM
cdaiscool's Avatar
If it's shaking when you hit your brakes, it's probably your brakes. Warped rotors or something.
As for everything else, I'm assuming that unplugged switch fixed it?
gobblebox59
Oct 2, 2004 03:44 PM
vxnine
Jun 8, 2004 11:36 AM
arkytec
Mar 10, 2004 06:49 AM
CaTiRo
16
Feb 14, 2004 08:18 PM
AzN_Flava
Nov 12, 2002 06:56 PM
