Advanced dizzy problem
Old Jul 7, 2011 | 02:15 PM
550whpcivic's Avatar
Default Advanced dizzy problem
So I checked the cam timing and it's lined up perfectly and the white mark for the tdc lines up with the cover over the timing belt. Now in order for me to put the timing at 16 degrees the dizzy is advanced all the way...... Any idea?
Old Jul 10, 2011 | 07:44 PM
Default Re: Advanced dizzy problem
bump
Old Jul 10, 2011 | 07:54 PM
Spawne32's Avatar
what spark plug wire do you have your timing light hooked up to
Old Jul 10, 2011 | 07:56 PM
lol number one closest to the cam gears..
Old Jul 10, 2011 | 07:57 PM
Spawne32's Avatar
dunno what to say then other then there must be something wrong with the internals of the distributor for it to be off that much
Old Jul 10, 2011 | 07:58 PM
Yeah I was thinking that
Old Jul 10, 2011 | 08:00 PM
Spawne32's Avatar
if you pull it apart, you should be able to see the gears that turn inside and see if you can see any problems with them, imo that would be the first place to look if the engine is timed right
Old Jul 10, 2011 | 08:03 PM
Yea I have a miss to about -7-8k rpms to. I think it's my plug wires, I have my plugs gapped at 20
Old Jul 10, 2011 | 08:04 PM
Spawne32's Avatar
that gap is pretty god damn tight lol im gapped at .044
Old Jul 10, 2011 | 08:05 PM
fully built lsvtec 2.0l s366 turbo
Old Jul 11, 2011 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
Just curious you are setting it to the middle line on the 3 lines closest together correct? Also make sure you are aiming the gun and looking down at the right place. If you look directly overhead the timing marks always look like its fully advanced, if you look from the side it'll be different. Also you are jumpering the blue connector by the passenger floorboard as well correct?
http://www.c-speedracing.com/howto/timing/timing.php
Old Jul 11, 2011 | 12:43 PM
YES THE MIDDLE OF THE 3(RED MARK) AND USING HONDATA S300
Old Jul 11, 2011 | 02:39 PM
http://www.youtube.com/watch?v=1SMPJNKaqzE
SW20FL
May 2, 2011 10:22 PM
thomas1214
Apr 1, 2008 12:05 AM
1bar_ek
Jun 9, 2005 06:12 AM
clovers
May 7, 2004 03:31 PM
b00stedbyFastrax
Mar 17, 2003 06:35 AM
