Engine Miss Problem
Old Jul 16, 2011 | 04:38 AM
Robinjo's Avatar
Default Engine Miss Problem
So my engine has had a slight miss only between 70-75 mph in 5th gear. It's only been a little annoying until now that the idle seems rough.
Any ideas?
Plugs look good. Did a full tune-up in the last bit with no effect. Exhaust is sealing fine. O2 replaced in the last year. I'm starting to run out of things to wate money on...... Tune-up and O2 sensor were do anyways, so it's no big loss there.
Old Jul 16, 2011 | 04:43 AM
Robinjo's Avatar
Default Re: Engine Miss Problem
I should also add this is a 1995 Integra GSR B18c1. No CEL. The miss doesn't happen at othere RPM's. No miss under full load. Only while cruising at 70-75 mph.
Old Jul 16, 2011 | 08:18 AM
fcm's Avatar
fcm
Old Fart
Because it is a common problem and an easy fix check the PGM-FI Main Relay... http://www.tegger.com/hondafaq/mainr...mainrelay.html
Old Jul 16, 2011 | 12:36 PM
Robinjo's Avatar
I will take a look at it....
Do you just resolder the points or replace the mai relay?
Old Jul 16, 2011 | 01:00 PM
Robinjo's Avatar
Main relay points all look wet. None of them look dry or cracked...
Any othere ideas?
Old Jul 16, 2011 | 08:55 PM
fcm's Avatar
fcm
Old Fart
I would resolder them anyway, heat them and add just a touch of solder, [60/40 resin core solder], it can't hurt. 94
Old Jul 16, 2011 | 09:11 PM
koss1229's Avatar
Ignition coil in the distributor overheating on higher rpm?
Old Jul 17, 2011 | 01:33 PM
Robinjo's Avatar
I cleaned th IAVC and FiTV. They were both really clean.
Still have the same problem...
Old Jul 18, 2011 | 01:14 AM
Robinjo's Avatar
Any other ideas?
This is miss getting pretty annoying now.....
Old Jul 18, 2011 | 05:42 AM
fcm's Avatar
fcm
Old Fart
Did you resolder the PGM-FI Main Relay connections, if for no other reason then to eliminate it as the problem?
When was the last time the fuel filter was changed?
Is this a problem only at 70-75 MPH in 5th gear or is it also a problem in any other gear, if not, I would check the TPS, maybe swap it out with a known good one. 94
Old Jul 20, 2011 | 01:37 AM
Robinjo's Avatar
I'm going to re-solder this weekend.
I'll see what I can do about the TPS.....
This is not a problem at any other speed or gear, I'll try at teh same RPM today in 4th on the way to work. It's only at cruising conditions....
Old Jul 20, 2011 | 03:55 PM
MechEng's Avatar
Check your cap and rotor, I had the same problem. New one solved the issue.
Old Jul 20, 2011 | 04:20 PM
SleepyPanda's Avatar
Victor Jónsson
Jun 27, 2013 10:01 PM
IMHARD2
Jun 24, 2008 02:43 PM
cioli
11
Jun 25, 2006 11:21 AM
cerpher
Aug 9, 2005 10:21 PM
