DA9 problem???
Old Jul 7, 2011 | 03:18 PM
kenobayburner's Avatar
Icon2 DA9 problem???
I have a 1994 DA9 with a ls motor & trans 5-speed. My sis had it for like a week and now it is not working lol I don't know what she did? but yea, when I could start... or try and start it it was making a sound like it was shooting air out of some where!? and losing power when i hit the gas! now the battery is died but i have another one any ideas? and the oil and water level is good so i dont think there's a hole in the block?...let me know please thanks!!!
Old Jul 7, 2011 | 10:12 PM
JdmVix's Avatar
Default Re: DA9 problem???
Not to be specific but it's not a "da9" when it passes 1993. Da's are from 1990-93. You have a dc2
Old Jul 8, 2011 | 05:47 AM
fcm's Avatar
fcm
Old Fart
So it will start, but will stall if you give it any gas, is that correct?
If so, check the valve timing, you, [your sister] may have skipped a tooth or two on the timing belt.
Do not try and start the engine until valve timing is checked.
Also make sure a spark plug has not "popped" out. 94
Old Jul 8, 2011 | 10:54 PM
o snap my bad i am a ej1 guy so it's called a dc2!? it dose not have the 4 round lights tho? o **** now i have to find the pink cuz it ant a 94 my bad it is a da?
yes it will want to stall out! i will check that and get back to you... o and the spark plug thing too THANKS!!!!!
Old Jul 9, 2011 | 11:16 PM
ok the timing is cool and the spark pug is cool steel don't know the year but yea let me know please any more ideas!!!
Old Jul 10, 2011 | 06:39 AM
fcm's Avatar
fcm
Old Fart
Look in the drivers door jamb, [or the door itself] there is a tag with the VIN and date of manufacture, or give us the VIN off the VIN plate on the drivers side of dash. 94
Old Jul 10, 2011 | 12:19 PM
hatmanafro's Avatar
Lmao.. 94 da9?!
Old Jul 11, 2011 | 05:18 PM
so I looked and it said....DA9 like i said i don't know the year but y do i need to know the year any way's you can put any Honda/Acura part on any Honda or Acura any wayz so haha i got the year wrong big wuup now that yall had your laughs can i get some help?
Old Jul 11, 2011 | 05:22 PM
i also tried to change sinsers that did not help i don't know the names of them but the one that has 2 water lines running in to it on the back of the manifold and the one on the fire wall next to the 2 round ones any other ideas??
Old Jul 12, 2011 | 05:32 AM
fcm's Avatar
fcm
Old Fart
Either give us the VIN or the build date, both are found on the label in the door jamb, without them there is not a lot of help we can give
Although a lot of parts on Honda/Acura are interchangeable not all of them are and not all are interchangeable from year to year.
I assume "sinsers" means sensors, if so, take a pic and post them so we can see what you mean.
Replacing parts before you know what is wrong is an expensive way to troubleshoot a problem. 94
Old Jul 18, 2011 | 12:27 PM
JH4DA9358LS028274 and i got the sensors off another da the one on the back of the manifold and the one that is missing on the firewall!? thanks for the help!!
Srt.ej1
Oct 22, 2015 10:23 PM
760dc4
Aug 7, 2009 05:31 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
hebrewhammer8
18
Jun 2, 2009 07:46 PM
sleepyitr
May 1, 2008 04:22 PM
