Db1 problem
Old Jul 14, 2011 | 03:42 AM
B16A-CRX's Avatar
Default Db1 problem
I have a 1990 db1 just replaced battery and alternator but my battery light still comes on. I checked all connections and grounds no problems seen. Every time I turn on the lights it wants to die. Any ideas what it can be?
Old Jul 14, 2011 | 06:25 PM
el crapitan's Avatar
Default Re: Db1 problem
the battery light only turns on when there is inadequate charging voltage. measure the charging voltage with a multimeter. should be roughly 14-14.5 volts.
if the connections are all clean and tight, i'd probably measure resistance of the B+ cable. should be 0 ohms or close to it
b16_swap
Mar 30, 2011 06:51 PM
b16_swap
14
Mar 30, 2011 07:25 AM
utn
Honda Civic (2001 - 2005)
Sep 24, 2009 04:31 PM
MDAnhorn
Dec 28, 2007 04:15 AM
dyases
13
Oct 5, 2003 09:50 AM
