door open light on?!?!?!?
Old Jul 1, 2011 | 06:34 PM
tonydize21's Avatar
Default door open light on?!?!?!?
hi my car a couple of days ago light of the trunk open came on and a said ok wth i can live with that but 2 days later the door open came on ,now both are on grrrrr!its there a fuse or something that could be causing this?or is just one of the switches has gone bad?
Old Jul 3, 2011 | 10:29 AM
sixfourkiller's Avatar
Default Re: door open light on?!?!?!?
i dont think it would be a fuse problem but maybe more like some loose wires maybe touching ground and cause the light to go on
Old Jul 3, 2011 | 07:52 PM
fcm's Avatar
fcm
Old Fart
Is it just the door and trunk/hatch open warning lights that are on, or are the dome and trunk/hatch lights also staying on?
As mentioned it will not be a fuse, the lights and the warning lights are controlled by grounds being supplied by door and trunk/hatch switches.
With that said, I would still check every fuse, it may be a totaly unrelated fuse, do not just eyeball the fuses, use a 12V test light on both test tips.
If the fuses are all good, unplug the switches, if lights still stay on, you have wires grounding to chassis or a ground lead. 94
Robinjo
Oct 20, 2010 04:26 PM
trex352
Jan 27, 2007 02:50 PM
reefranger
Oct 2, 2005 02:54 PM
mozzy
Sep 18, 2004 07:56 AM
