OEM Fuel Pump or Walbro
Every now and then when I'll be driving my car will sort of bog and it feels like the car isn't getting any fuel. Previous to this I have done a full tune-up, timing belt,water pump (this had to be done anyway), and even tried using fuel cleaner (I think it helped for a bit). My GF's Jetta had the same issue and it turned out to be the fuel pump. So I was thinking of getting a new pump. However before doing all this, would it be smart to just change out the Fuel Pump Stock before spending money on the whole assembly?
The car has no CEL, and it's a 01 GSR.
So now the question remains if I do decide to buy the whole set by going OEM or Walbro. I won't need any type of fuel regulator on a Walbro right (after some research some people said to do this? Doesn't sound right if I'm not getting a performance fuel pump).
Re: OEM Fuel Pump or Walbro
I'd also assume that the filter is more likely to be clogged than the pump fail.
If your girl's Jetta lost the pump, the filter should be changed before it kills the new pump too. I had to do that once for my wife's A4, when the clogged filter killed the pump...
I would assume (so I could very well be wrong here) that low fuel pressure would throw a CEL.
Depends on your setup. Stock fuel pumps can handle at least 200WHP and from experience if a fuel pump is bad, it would just die on you.
You do not need an aftermarket fuel regulator to run a Walbro 255lph. I had one with a stock rail and regulator.
OP, pull and read the plugs. If it's running lean or rich, they'll tell you.
