DASH HARNESS HELP!!
Old Nov 15, 2011 | 05:05 AM
90efb16's Avatar
Default DASH HARNESS HELP!!
Hey guys I have a question, I have a 95 integra gsr and I have a short in the dash wiring harness. I was wondering if i can use a harness out of a 96-01 integra. The part numbers are different 94-95 same part number but 96-01 different part number. Probably bc of being 0bd2 and mine being obd1. I could fix mine there is only 5 wires that are burnt but fixable. I guess I'm just wondering if anyone has used another year in there car?
Old Nov 15, 2011 | 05:43 AM
fcm's Avatar
fcm
Old Fart
Default Re: DASH HARNESS HELP!!
If the part numbers are diff. then most likely it is more work to mod the 96-01 harness then to repair your harness.
Why not hit up your local bone yards, [PicknPull] and see if you can find a good harness out of a 95-95? 94
Old Nov 15, 2011 | 05:57 AM
90efb16's Avatar
I mean I could try but I might just be better off fixing mine with some soldering and shrink wrapping it
Old Nov 15, 2011 | 04:35 PM
fcm's Avatar
fcm
Old Fart
It would definatly be cheaper.
Kind of depends on how much damage there is, how far "back" into the harness it goes.
What part of the harness is damaged, got pix? 94
Old Nov 16, 2011 | 04:23 AM
DPancoast's Avatar
I dont know if its this simple, but can you use a 96+ cluster like you are saying and just buy an ob2 ---> obd1 (thats what you currently have right?) jumper harness and just swap the new harness and jumper in and call it a day?
A lot of work, but its just an idea. I also have a complete 96 car harness sitting around if you wanted to work out a deal. I crashed back in May and tore the entire car down to bare chassis. When I swapped over to a new shell I didnt need it since im on an obd1 ecu w/hondata.... new shell (94 gsr) just plugged right into my ecu since its obd1 so I have no use for the harness out of the 96.
Old Nov 16, 2011 | 05:38 AM
90efb16's Avatar
Thanks for the offer but I think that would cost me more money then buy a new harness. Acura doesnt have the harness available anymore and I found a couple used for 150 bucks. I decided to just fix mine with some solder and shrink wrap. It was only five wires that were melted together.
brandonEM1
Engine Management and Tuning
Nov 24, 2013 04:21 PM
civic-steve-94
10
May 24, 2011 09:20 PM
boostedb20z
Oct 28, 2009 11:22 AM
crazy_joe
Audio / Security / Video
Oct 24, 2008 08:53 AM
v-tec maz
Jan 8, 2006 07:01 PM
