GSR question need answer quick
Old Oct 29, 2011 | 06:35 PM
kylesmith3251's Avatar
Icon2 GSR question need answer quick
I have a full type r conversion GSR car but still have the stock gsr motor in it I have a set of type r pistons and rods I was told they will fit right in my car no problems cause the rods are very similar to gsr well I bent 2 rods in it and now its time they go in but I wanted to make sure there wont be a problem putting them in I wanna make sure clearance is good an make sure that they will fit on the crank properly ur help will be much appreciated thanks
Old Oct 29, 2011 | 07:06 PM
92civiceg9gsr's Avatar
Default Re: GSR question need answer quick
Yes they fit. If your using the stock type r rod bolts they should be torqued with a strect gauge.
Old Oct 29, 2011 | 07:32 PM
Ok whats the torque specs on them? An how much better yu think it will be performance wise thanks for the info
Old Oct 29, 2011 | 07:35 PM
tam4511's Avatar
if you want more torque use a ls crank and ls rods, they have more stroke (more torque) and use them with you Type R pistons. Pick up some arp rod bolts and you wont have any problem reving to gsr/typr rev limit.
Old Oct 29, 2011 | 07:43 PM
What will compression be after I put em in? Sorry for pickin all yu guys brains lol ive built mad singles junew wi stuff such as this in b series just traded my vitara build for this
Old Oct 29, 2011 | 07:47 PM
tam4511's Avatar
around 11:1, pump gas limit is 12+:1 so you have plenty of room to tune.
Old Oct 29, 2011 | 08:05 PM
Yeah I drive a dragster I order 114 oct by the drum but im not bout to use it all in my daily lol on average how much hp will it add
Old Oct 29, 2011 | 08:12 PM
tam4511's Avatar
I'm not sure, I just know the stroke is significantly longer. Google similar setups.
NaIsGay
Jun 22, 2009 07:48 PM
killerB16A
24
Mar 10, 2009 02:33 PM
projectstacy
Dec 4, 2007 09:49 AM
5_Lug_B
Sep 6, 2007 12:52 PM
slayersluck
Jun 16, 2005 05:03 AM
