DA3 high rev problem
I have been having an issue with my idle rev.
I have turned the idle screw till it won't turn anymore. Plus I have checked if the acceleration cable was stuck but it is normal there.
is there something I might be missing here?
here is a youtube video
http://www.youtube.com/watch?v=QFN5J...el_video_title
You sure your thorttle is closed all the way? loosen the cable adjuster and see if the idle drops or you have a serious vac leak.. get a can of brake clean and let it run and spray around where all the intake gaskets are. If the idle drops then you have a leak at that gasket
Ahhhlee
10
Jun 24, 2010 02:05 PM
Car Tweaker
Sep 13, 2009 08:28 PM
