Power locks. Need help.
Old Nov 12, 2011 | 03:06 PM
nWilk666's Avatar
Icon2 Power locks. Need help.
Well i've had this problem for awhile but haven't felt like fixing it. But recently i got a key less entry/remote start and need it to work.
So here's the problem.. When you pull the driver door handle out to lock it, it doesn't turn the lock. You have to pull the handle out and push it yourself for it to lock. With this problem it makes my keyless entry pretty much pointless. I was wondering if anyother people on here have had this problem and could give me some advice.
Thanks, Nick.
Old Nov 12, 2011 | 09:16 PM
kchungb17a's Avatar
Default Re: Power locks. Need help.
Is this just one door? all doors? Is it the inside door lock switch that you are using? Does it lock when the door is closed? Year and trim please.
Old Nov 13, 2011 | 05:07 PM
nWilk666's Avatar
yes just the driver side door. It's a 94 gsr. It still does the same thing with the door opened/closed. Thanks.
Old Nov 14, 2011 | 03:08 PM
nWilk666's Avatar
bump
Old Nov 14, 2011 | 03:14 PM
TunerN00b's Avatar
Thanks, Nick.
Why are you pulling on a door handle to lock the door?
2000 GSR, and to lock it I either hit the lock button, or flip the lock switch (why it has both, I have no clue), but either way no messing with the door handle needed...
Old Nov 14, 2011 | 03:15 PM
mark@silbernage's Avatar
Not clear if you're describing an electrical or mechanical prob - let's see...
I don't pull the inside door handle to lock the door (or outside for that matter).. I either use the electrical switch to lock (if I'm inside) or the key (there's an electrical switch on the lock itself that electrically locks all doors when the key is turned CCW to lock.
If the electrical stuff isn't working properly - that's one diag path we can go down.
If the lock button in front of the inside driver's door handle doesn't mechanically lock the door when rotated (and the red/orange part disappears), then you have a mechanical problem inside the door - that's a separate diag path we can discuss. For that you'd pull the inside panel and inspect the rods and how they're connecting to the latch mechanism.
Or -- are you describing a different function?
Old Nov 14, 2011 | 05:00 PM
nWilk666's Avatar
On every honda i have ever owned, when you go to lock your driver side door you have to pull your handle out then press lock to prevent locking keys in your car. My problem is when i go to do that the moving part on the lock ( i dont know the correct word) does not move i have to push it with my hand like its binding up or hanging up.
Old Nov 14, 2011 | 05:01 PM
nWilk666's Avatar
Or -- are you describing a different function?[/QUOTE]
this is my problem..
Old Nov 14, 2011 | 06:07 PM
TunerN00b's Avatar
Strange. Definitely not the case with my 2000 GSR. I don't remember if my 91 LS needed that though...
Old Nov 14, 2011 | 06:13 PM
nWilk666's Avatar
ya.. its been the same on a 96 ex, 00 si, 97 ex and 92 rs for me atleast..
Old Nov 16, 2011 | 03:46 PM
kchungb17a's Avatar
nWilk666: you are correct. On any Honda, if you try locking the doors on a front door with that door open, you do need to hold the door handle in the open position while pressing the switch, otherwise the locks will unlock automatically.
Do both doors lock if you use the lock switch on the passenger side? If yes, you may have a bad driver's side switch or wiring in between switch and actuator. If no then you have a bad driver's side door lock actuator.
GL
Old Nov 16, 2011 | 09:29 PM
Tak_9's Avatar
i have the same problems
Old Nov 17, 2011 | 05:36 AM
nWilk666's Avatar
GL
It does not lock with both doors closed from the passenger side. So i'm guessing its the driver side door lock actuactor.
Thank you sir.
Old Nov 17, 2011 | 07:13 AM
nWilk666's Avatar
Fixed it. Took door panel off and lubed all the lines with lithium grease. works great now.
Red-Rag-B18
Acura TSX
Apr 30, 2013 09:12 AM
blacktibby07
Feb 5, 2011 06:37 AM
alacard
16
Jan 25, 2007 09:55 AM
rkrone
May 19, 2006 10:05 PM
patastinky
Jan 29, 2003 10:05 AM
