90-94 engine mount question
Old Nov 2, 2011 | 06:26 AM
89luderSi's Avatar
Default 90-94 engine mount question
so what i gather from my research tell if im wrong that the left side/drivers side, engine mounts had some changes that started in 92, the actual metal bracket that bolts to the engine block is the same from 90-93 but the mount on the frame rail of the car was moved further forward and a touch outword a little, therefore not allowing a 90-91 rubber mount between the two pieces work on the 92-93 integra. and creating us to use 90-91 specific mounts on a 90-91 car and 92-93 mount only on a 92-93 car.
i need to replace my left engine mount on my 92 integra with a ls and i had another mount laying and around and i was going to put it in then found out it did not line up with the mount on the frame at all, making me realize it was from my 91 integra i had that, they must have changed it starting in 92.
any thoughts? comments?
Old Nov 2, 2011 | 08:19 AM
89luderSi's Avatar
Default Re: 90-94 engine mount question
bump
Old Nov 3, 2011 | 04:31 AM
89luderSi's Avatar
Bump
B00M3R
Feb 17, 2010 02:02 AM
Neukin
Feb 28, 2005 08:18 AM
Loveless
Oct 14, 2003 09:52 AM
