loud "knocking", pulled head, piston not level??
P8R head
crower 403s
PR3 pistons/Stock LS bottom end
Dring home from work, I noticed a tapping, knocking sound from the engine. I pulled over, looked over everthing, and didnt see anything out of the normal. I figured it was my valves, and was going to be adjusting them. As I jumped on the hwy, it dies, with the knocking and tapping louder than ever. I got it towed home, adjusted the valves to specs(they were still close to spec), sealed everthing back up, and the tapping, knocking was still present. Figuring I must have burnt a valve, I pulled the head and when I was spining the crank, I noticed cylinder 2 and 3 pistons were level to the deck, but piston 4 was sitting under the deck line, lower than 1, about an 1/8. Also, piston 4 has turning play, Id say, 1/8th play. Spun bearing??
Cliff notes: a loud knocking, tapping, is present, no CEL, lost in power, cyl piston 4 sits lower than cyl. piston 1.
crower 403s
Re: loud "knocking", pulled head, piston not level??
P8R head
crower 403s
crower 403s
if your super lucky all u need is to replace the bearing... but in most cases you need to remove the engine and begin checking whats in spec and whats out of spec... most likely your crank will need to be knife edged.. your pistons can be rebuilt and then u can get new bearings and it should be fine as long as nothing in the upper end was ruined by heat.
I am going try and respond to all, but a compression test would be out of the question. About a week before all of this nonsense, I did pull one. If I remember correctly, from right to left, 210, 205, 200 and 199ish. I wasn't blowing smoke at all, of any color, and not over heating. Oil level was always fine. I kept up with oil changes. When I rebuilt the engine, I had the head milled, and the block checked for warpage. Block was in great shape, and after looking at my compression test results, I see a trend.....doh! I havent had time to take a look underneath, but when I do, I will keep updates. Spun bearing, check.....
GetSTROKED
10-19-2006 03:39 PM
