idle problem on b16a
Old Nov 3, 2011 | 06:04 PM
nates97coupe's Avatar
Default idle problem on b16a
swapped a jdm b16a in my 95 teg
it idles at 1500 but when it warms up it begins to idle surge 1500-1550rpm. bad TPS, IACV or vacuum leak?
Also when its cold it takes me sometimes up to 8 times for it to stay idling. it will crank over idle for a second then die, but when it warms up a tiny bit it stays idling. but when warm outside it only takes 2 or 3 times..why does it do this? i appreciate any help.
and when im driving, itll almost two step when i hit 1500rpm, but when i give it half throttle or a little more it will go right past it
thanks
Old Nov 4, 2011 | 08:32 AM
Default Re: idle problem on b16a
ttt need help asap
Old Nov 4, 2011 | 08:00 PM
RTUNED BUILT's Avatar
first of all try to check for any cel.. second make sure all youre harness connections go were they belong..
Old Nov 4, 2011 | 11:04 PM
Quik Chris's Avatar
thanks
I'd first check the IACV. Understand that you might destroy the T-body gasket doing this.
  • Crimp the coolant lines on each side, pull the throttle body.
  • On the bottom of the T-body, undo the top to the IACV
  • Inside, there's a piece that looks to be a large, white, plastic screw with a flathead relief. Turn this clockwise to tighten.
  • Reinstall (reverse of removal)
  • Start car, wait for the radiator fans to come on while idling to ensure problem has been fixed
Old Nov 4, 2011 | 11:14 PM
661rex89si's Avatar
first check for vacuum leaks high idle is usually that issue
2nd iacv take it off and clean it
3rd clean your tb as well
4th check for air bubbles in your coolant it cause idle issues as well
5th check your pcv
6th check your ignition if your getting some kind of backfire which makes you think you have 2 step.
The Dirty EJ1
Apr 30, 2013 06:44 AM
j0nbunklah0m
21
Aug 11, 2010 01:56 PM
speedfreak44
Apr 14, 2010 06:36 PM
Irish Integra
Mar 31, 2005 02:30 PM
