HELP! electtical issuse
Old Oct 22, 2011 | 07:45 AM
speedster0020's Avatar
Default HELP! electtical issuse
My driver side headlight/signal doesn't have any power at all, I checked fuses there still good,tested volts no power, but the driver sidde has power and works just fine.... This is really turning into a real head scratcher.. any info would be great Thx
Old Oct 22, 2011 | 12:17 PM
fcm's Avatar
fcm
Old Fart
Default Re: HELP! electtical issuse
OK, to start we will need MM&Y of car, I am assuming it is a G3 Integra and will go with that unless you say diff.
Also, exactly what lights do not work...
"My driver side headlight/signal doesn't have any power at all"
"but the driver sidde has power and works just fine.... "
Your going to have to clarify.
Also, is it high beam, low beam, front signal, front side marker and/or park lights??? 94
Old Oct 22, 2011 | 07:24 PM
Passenger side has full power.. low beam driver/signal no power whatsoever , its a 95 gsr
Old Oct 22, 2011 | 10:59 PM
angeldckid's Avatar
Wat about the rear lights on driverside still working. ?
Old Oct 23, 2011 | 12:30 AM
rickyracer's Avatar
make sure when you test the fuses the light are on...that fuse will only get power when the switch is activated. there's also 2 fuses, one for the left and one for the right.
Old Oct 23, 2011 | 08:50 AM
bonstokLS's Avatar
Post Re: HELP! electtical issuse
Really? Good to know. I just thought it was one fuse for front headlights. I never checked but good to know!
Old Oct 23, 2011 | 09:29 AM
fcm's Avatar
fcm
Old Fart
Actually there are 4 fuses for the head lights...
fuse 10-10A left high beam and high beam indicator.
fuse 9-10A right high beam.
fuse 21-10A right low beam.
fuse 22-10A left low beam.
Above are in under dash fuse box.
The signal lights are on one fuse, fuse 26-10A in AUX fuse holder.
The drivers side signal has nothing to do with the fuse, it is either a bad bulb or a connection problem, if you tested for power and there was none then there is a connection problem.
To be clear are you are talking about the duel filament bulb, [park and signal light] in the bumper, or do you mean the single filament front side marker, [also a park and signal light that is controled by the ICU]??? 94
Realdon65
Honda CR-V & Element
Sep 4, 2021 12:15 PM
mcleary333
Nov 30, 2013 04:39 PM
johnnynguy3n
Honda S2000
Mar 27, 2010 05:13 AM
JThrasher79
Mar 12, 2007 01:58 PM
