Input Needed!!
Old Nov 3, 2011 | 07:45 PM
91-lsvtecsi's Avatar
Default Input Needed!!
I just took off my turbo manifold on my integra and noticed i had oil in the exhaust port...its the same cylinder my previous block cracked a sleeve on... I swapped a new block and ran it for about 30mins and just took off the manifold to swap in topmount. Ive also had the machine shop put in new valve seals... Cracked head? Bad Valve seals? Any test I can perform to narrow it down? Thanks!!!
Old Nov 3, 2011 | 07:49 PM
DirtyDA9's Avatar
Default Re: Input Needed!!
If the valve seals were replaced then I doubt that's it, and if it's a stock bottom end you swapped in then maybe rings? I would lean towards a cracked head though...
Old Nov 3, 2011 | 07:58 PM
Damn this is bullshit! LOL...How can I confirm its my oil control rings? I believe i would get the head pressure tested for cracks?? What would a leakdown test tell me? Thanks
Old Nov 3, 2011 | 08:21 PM
DirtyDA9's Avatar
To check if it's the oil rings do a leak down test and listen in your dipstick tube or oilpan for noise. I'm not sure how they can pressure test for cracks. Machinists are crafty so I'm sure they have some way of doing it.
Leakdown test will only tell if you have any of these problems:
A. Bad valve seats/ leaky valve
B. Bad head gasket
C. Bad piston rings.
D. Bad spark plug threads.
Old Nov 3, 2011 | 08:23 PM
Dioxine's Avatar
Leakdown test would tell you if your rings were bad. Did the motor smoke at all when you had it running?
Old Nov 4, 2011 | 09:45 AM
No smoke call me retarded But i do remember pouring some oil in each cylinder to do compression test lol Maybe i poured too much
Old Nov 4, 2011 | 07:42 PM
DirtyDA9's Avatar
haha well that could do it!
Old Nov 4, 2011 | 07:45 PM
Dioxine's Avatar
Lol yeah i wouldnt worry about it unless you have problems with it smoking once you get it back together.
Old Nov 4, 2011 | 07:57 PM
10psiLsEf2's Avatar
wat kind of turbo?
check for shaft play
Old Nov 4, 2011 | 08:13 PM
Dioxine's Avatar
Originally Posted by 10psiLsEf2
wat kind of turbo?
Seems unlikely that an under mounted turbo could spit oil up into an exhaust port.
Old Nov 4, 2011 | 08:20 PM
10psiLsEf2's Avatar
rebuild kit
DirtyDA9's Avatar
If it was the turbo it would be in the downpipe not the manifold. And it would be smoking.
Old Nov 4, 2011 | 08:30 PM
Dioxine's Avatar
Thats what i was thinking. The oil wouldnt travel agianst the force of the exhasut. What the hell are you talking about 10psilsef2.
Old Nov 4, 2011 | 09:00 PM
DirtyDA9's Avatar
Lol he may have just read it wrong thinking the oil was in your exhaust or something...
But yea I would have to say that the oil is from your wet compression test. Let us know what happens after you start it back up.
G3teg96
Aug 20, 2011 05:00 PM
youryanyou
Apr 5, 2010 08:14 AM
hondab20t
12
Oct 3, 2006 06:38 PM
So Cal So Boosted
Aug 5, 2004 11:41 AM
GsrSdn
Oct 9, 2002 03:16 PM
