Stumped on speed sensor...need some help
Old Oct 10, 2004 | 06:55 AM
EV1L SI's Avatar
SCAM ARTIST
Default Stumped on speed sensor...need some help
Ok so the speed sensor on my 95 GSR went out and I bought a used one from a HT member a while back. Well just the other day I get around to finally swapping them out and I come to find out the sensor he sent me looks COMPLETELY different than the one that came out of my transmission. On the one I bought, none of the bolt holes line up with my tranny case, but it does fit down into the hole and plugs into the wiring harness. I figured I would try it out anyways.
I put the new sensor into my tranny and plugged it in and took a drive around the block and what do you know, it worked. I was surprised. So I got on the throttle some and engaged VTEC then shifted gears. After I shifed gears, I noticed my speedo went back down to 0 and stayed there and the CEL came on for code 17 (VSS). I took the sensor out and repositioned it today and it worked again, but as soon as VTEC engages, the speedo goes back down to 0. If possible I would like to use this sensor but I will probably have to buy another one.
Any clues as to why it stops working when VTEC hits?
and a big to the guy that sold it to me saying it was made for my car. It looks nothing like my old one.
Old Oct 10, 2004 | 05:23 PM
EV1L SI's Avatar
SCAM ARTIST
Default Re: Stumped on speed sensor...need some help (GSR Coupe)
help
Old Oct 10, 2004 | 06:34 PM
Tweakmeister's Avatar
What is there to know?
If it's completely different then odds are it's the same Honda plug, the same chunk of geared metal, but a different sensor. ?!?
DarkDragon
Oct 21, 2013 09:03 PM
matavtec
Jun 12, 2009 05:14 PM
RAS Motorsports
Oct 15, 2004 10:44 AM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
