Integra 92 axles
Integra 92 axles
hey ! what do you have to change when your axles got messed up ? My 92 teg axle on the passenger side got messed up a couple days ago. there is some kinda noise, it is weir when ever I makes a turn. the teg has 127k on it and I think maybe that is the reason Y. Can you guys please tell me what I have to change when I change the axle ? what do you recommend and how much do they usually cost? Thanks a lot guys.
Re: Integra 92 axles (SIGNAL LS-R)
u need a new axle...it would cost around 60 bucks with your old one as a core...its really easy to change out...get a new axle nut as well in case u mess up ur old one...dats about all u need...juss pop the old one out and goes in the new one...
Re: Integra 92 axles (hybridracer504)
60 bucks. is that for a used one or new? and where can I get it ? Its cheap if 60 bucks for a new one.
Thanks bro.........
Thanks bro.........
Re: Integra 92 axles (sabotage7)
yea...dats a remanufacture one at autozone...or any otha parts store...u also get a lifetime warranty for it so if it ever breaks again juss bring it back and they will give u a new one...
Just take off the axel and lower ball joint nut and pop it. take out the through bolt that holds the shock mount to the lca. pull the axel from the hub and w/ a screw driver or a small pry bar. pop it out of the tranny or intermediate shaft depending on what side your doing
namechangeagain
21
05-04-2004 10:59 AM
