golden eagle block guard question
Old Oct 9, 2004 | 08:50 PM
s2kkid's Avatar
Default golden eagle block guard question
This is to people who have experience with their product.
1. Will this cause any overheating issue?
2. Can i put this piece in my self, or is it SO tight that it must be pressed in
3. If youve ran this could you breefly describe what youve put the motor through(psi) etc.
Ps. I am having the block decked, and the cylinders honed after installation, to ensure if anything moves alittle while the b-g is being installed, that it will be true again.
Old Oct 9, 2004 | 09:06 PM
B00ST2nR's Avatar
Default Re: golden eagle block guard question (vtecluder97)
I'll be using a Golden Eagle Block Guard with my Turbo Setup. I know a friend who's also running this and it's doin fine.
You can check out pictures in my Sig.
Old Oct 9, 2004 | 09:07 PM
PaChiLa Leader's Avatar
Default Re: golden eagle block guard question (B00ST2nR)
what does it do exactly?
Old Oct 9, 2004 | 09:08 PM
lanojp1's Avatar
Default Re: golden eagle block guard question (PaChiLa Leader)
keeps the cylinders from oval'n...
Old Oct 9, 2004 | 09:24 PM
s2kkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR &raquo;</TD></TR><TR><TD CLASS="quote">I'll be using a Golden Eagle Block Guard with my Turbo Setup. I know a friend who's also running this and it's doin fine.
You can check out pictures in my Sig.</TD></TR></TABLE>
I thought you were going with a race hi-flow block guard...
what made you change to golden eagle.
I read someone had theirs welded in... What kind of metal is in the coolant passages, Would the machiene shop be able to get 4 good spot tacks in each corner?
Old Oct 9, 2004 | 09:31 PM
B00ST2nR's Avatar
Oh **** my bad... I meant Race Engineering Hi-Flow block guards. Not GE.
Modified by B00ST2nR at 12:02 AM 10/12/2004
Old Nov 2, 2004 | 09:11 PM
95gsrturbo's Avatar
I ve been reading that some people have run block guards (many actually with good success)
I purchsed on already but am debating on the install-
the head is already coming off for a swap- why not? well im worried about warping (egg shaped) cyl walls
Im using golden eagle so should be a really good fit, but who knows
if i have to use a rubber mallett to tap it in and CANNOT hone- i should abort right?
or do you guys suggest abort now anyway even with GE
Old Nov 3, 2004 | 10:30 AM
95gsrturbo's Avatar
Default Re: golden eagle block guard question (95gsrturbo)
up
djxtreme808
Sep 29, 2008 05:36 PM
BlangBlangTEG-93'
Mar 2, 2007 08:18 AM
the DA in HONDA
Aug 3, 2004 10:48 PM
miller
Dec 16, 2003 02:30 PM
Nextelbuddy
Jun 18, 2003 08:01 AM
