CEL 22
Old Oct 11, 2004 | 04:26 AM
WhatThaFrig's Avatar
Default CEL 22
My check engine light came on last week and I finnally checked the code and it was 22,VTEC pressure valve. What exactly does this entail? Now the light is off. The car is an 01 GSR.
Thanks.
Old Oct 11, 2004 | 06:57 AM
JimBlake's Avatar
Default Re: CEL 22 (WhatThaFrig)
VTEC oil pressure switch. It's a green plug forward & down from the distributor. When the ECU engages VTEC, it wants to see sufficient oil pressure. If it doesn't, it sets code 22.
First, check your oil. Then check the wiring... or maybe a bad pressure switch? There's a screen in the gasket between the VTEC spool-valve & the head. Maybe that's dirty & clogged.
Worst case, if you've got a REAL oil pressure problem then you can check your oil pickup in the pan, or maybe your oil pump.
Old Oct 11, 2004 | 07:31 AM
Full Race EG's Avatar
Default Re: CEL 22 (JimBlake)
Old Oct 11, 2004 | 10:52 AM
Cool! Thanks. I did have to put a new dipstick tube in yesterday,and now the light is off. Maybe the old dipstick was causing the fault?
Old Oct 11, 2004 | 12:14 PM
GsrGilbert's Avatar
yea ive been running the same code off and on. started happing twhen i did the vafc2 install. all the wiring is fine on the piggyback i still havent been able to find the sorce of the code.
jchrm80
Apr 5, 2007 01:22 PM
drudy
Aug 26, 2005 12:20 PM
redman223
Jul 2, 2003 03:45 PM
BeeResp0nsible
Nov 29, 2002 05:43 AM
311
Oct 23, 2002 08:20 AM
